On this page
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Spark/Spark2x/ Spark Core Enterprise-Class Enhancements/ Configuring Spark HA to Enhance HA/ Configuring the Switchover Between the Multi-active Instance Mode and the Multi-tenant Mode
Updated on 2024-12-13 GMT+08:00
When using a cluster, if you want to switch between multi-active instance mode and multi-tenant mode, the following configurations are required.
  • Switch from multi-tenant mode to multi-active instance mode.
    Modify the following parameters of the Spark2x service:
    • spark.thriftserver.proxy.enabled=false
    • spark.scheduler.allocation.file=#{conf_dir}/fairscheduler.xml
    • spark.proxyserver.hash.enabled=false
  • Switch from multi-active instance mode to multi-tenant mode.
    • spark.thriftserver.proxy.enabled=true
    • spark.scheduler.allocation.file=./__spark_conf__/__hadoop_conf__/fairscheduler.xml
    • spark.proxyserver.hash.enabled=true
Configuration Description
Log in to Manager and choose Cluster > Services > Spark2x. Click Configurations, click All Configurations, and search for and modify the following parameters:
Table 1 Parameter description
Default Value
Specifies whether to use the multi-tenant mode.
  • false: The multi-instance mode is used.
  • true: The multi-tenant mode is used.
true
Specifies the fair scheduling file path.
  • If the multi-active instance mode is used, the path is changed to #{conf_dir}/fairscheduler.xml.
  • If multi-tenant mode is used, the path is changed to ./__spark_conf__/__hadoop_conf__/fairscheduler.xml.
Specifies whether to connect to ProxyServer using the Hash algorithm.
  • true indicates using the Hash algorithm. In multi-tenant mode, this parameter must be configured to true.
  • false indicates using random connection. In multi-active instance mode, this parameter must be configured to false.
true
After this parameter is modified, you need to download the client again.
