Updated on 2025-08-22 GMT+08:00
Permission Parameters of the Spark Client and Server
This section describes how to configure SparkSQL permission management functions (client configuration is similar to server configuration). To enable table permission, add following configurations on the client and server:
  • spark-defaults.conf configuration file
    Table 1 Parameter description (1)
    Example Value
    spark.sql.authorization.enabled
    Specifies whether to enable permission authentication of the datasource statement. It is recommended that the parameter value be set to true to enable permission authentication.
    true
  • hive-site.xml configuration file
    Table 2 Parameter description (2)
    Example Value
    hive.metastore.uris
    Address of the Hive Metastore service.
    thrift://10.10.169.84:21088,thrift://10.10.81.37:21088
    hive.metastore.sasl.enabled
    Whether the Metastore service uses SASL to improve security. The table permission function must be enabled.
    true
    hive.metastore.kerberos.principal
    Principal of the Hive Metastore service, for example, hive/hadoop.<system domain name>@<system domain name>.
    hive-metastore/_HOST@EXAMPLE.COM
    hive.metastore.thrift.sasl.qop
    After the Spark SQL permission management function is enabled, set this parameter to auth-conf.
    auth-conf
    hive.metastore.token.signature
    Token identifier of the Metastore service.
    HiveServer2ImpersonationToken
    hive.security.authenticator.manager
    Authentication manager of the Hive client.
    org.apache.hadoop.hive.ql.security.SessionStateUserMSGroupAuthenticator
    hive.security.authorization.enabled
    Whether to enable client authorization.
    true
    hive.security.authorization.createtable.owner.grants
    Permissions granted to the owner who creates the table.
    ALL
  • core-site.xml configuration file of the MetaStore service
    Table 3 Parameter description (3)
    hadoop.proxyuser.spark.hosts
    Specifies the hosts from which Spark users can be masqueraded, which is set to *, indicating all hosts.
    hadoop.proxyuser.spark.groups
    Specifies the user groups from which Spark users can be masqueraded, which is set to *, indicating all user groups.
