Creating a Spark SQL Role
This section describes how to create and configure a Spark SQL role on Manager. The Spark SQL role can be configured with the Spark administrator permission or the permission of performing operations on the table data.
Creating a database with Hive requires users to join in the hive group, without granting a role. Users have all permissions on the databases or tables created by themselves in Hive or HDFS. They can create tables, select, delete, insert, or update data, and grant permissions to other users to allow them to access the tables and corresponding HDFS directories and files. The created databases or tables are saved in the /user/hive/warehouse directory of HDFS by default.
Notes and Constraints
- If the current component uses Ranger for permission control, you need to configure permission management policies based on Ranger. For details, see Adding a Ranger Access Permission Policy for Spark2x.
- After Ranger authentication is enabled or disabled for Spark, you need to restart Spark and download the client again or update the client configuration file spark/conf/spark-defaults.conf.
To enable Ranger authentication, set spark.ranger.plugin.authorization.enable to true.
To disable Ranger authentication, set spark.ranger.plugin.authorization.enable to false.
- Log in to Manager, and choose System > Permission > Role.
- Click Create Role and set a role name and enter description.
- Set Configure Resource Permission. For details, see Table 1.
- Hive Admin Privilege: Hive administrator permissions.
- Hive Read Write Privileges: Hive data table management permission, which is the operation permission to set and manage the data of created tables.
- Hive role management supports Hive administrator permissions and the permissions to access tables and views, but does not support granting permissions on databases.
- The permissions of the Hive administrator do not include the permission to manage HDFS.
- If there are too many tables in the database or too many files in tables, the permission granting may last a while. For example, if a table contains 10,000 files, the permission granting lasts about 2 minutes.
- Click OK.
