Adding a Ranger Access Permission Policy for HBase
Ranger administrators can use Ranger to configure permissions on HBase tables, column families, and columns for HBase users.
- The Ranger service has been installed and is running properly.
- You have created users, user groups, or roles for which you want to configure permissions.
- Log in to the Ranger web UI as the Ranger administrator rangeradmin. For details, see Logging In to the Ranger Web UI.
- On the home page, click the component plug-in name in the HBASE area, for example, HBase.
- Click Add New Policy to add an HBase permission control policy.
- Configure the parameters listed in the table below based on the service demands.
Table 1 HBase permission parameters Parameter
Policy Name
Policy name, which can be customized and must be unique in the service.
Policy Conditions
IP address filtering policy, which can be customized. You can enter one or more IP addresses or IP address segments. The IP address can contain the wildcard character (*), for example, 192.168.1.10,192.168.1.20, or 192.168.1.*.
Policy Label
A label specified for the current policy. You can search for reports and filter policies based on labels.
HBase Table
Name of a table to which the policy applies.
The value can contain wildcard (*). For example, table1:* indicates all tables in table1.
The Include policy applies to the current input object, and the Exclude policy applies to objects other than the current input object.
NOTE:The value of hbase.rpc.protection of the HBase service plug-in on Ranger must be the same as that of hbase.rpc.protection on the HBase server. For details, see Existing HBase Tables Cannot Be Searched Using Wildcards When HBase Permission Policies Are Configured.
HBase Column-family
Name of the column families to which the policy applies.
HBase Column
Name of the column to which the policy applies.
Policy description.
Audit Logging
Whether to audit the policy.
Allow Conditions
Policy allowed condition. You can configure permissions and exceptions allowed by the policy.
In the Select Role, Select Group, and Select User columns, select the role, user group, or user to which the permission is to be granted, click Add Conditions, add the IP address range to which the policy applies, and click Add Permissions to add the corresponding permission.
- Read: permission to read data
- Write: permission to write data
- Create: permission to create data
- Admin: permission to manage data
- Select/Deselect All: Select or deselect all.
If users or user groups in the current condition need to manage this policy, select Delegate Admin. These users or user groups will become the agent administrators. The agent administrators can update and delete this policy and create sub-policies based on the original policy.
To add multiple permission control rules, click
. To delete a permission control rule, click
.Exclude from Allow Conditions: policy exception conditions
Deny All Other Accesses
Whether to reject all other access requests.
- True: All other access requests are rejected.
- False: Deny Conditions can be configured.
Deny Conditions
Policy rejection condition, which is used to configure the permissions and exceptions to be denied in the policy. The configuration method is similar to that of Allow Conditions.
The priority of Deny Conditions is higher than that of allowed conditions configured in Allow Conditions.
Exclude from Deny Conditions: exception rules excluded from the denied conditions
Table 2 Setting permissions Task
Role Authorization
Setting the HBase administrator permission
- On the home page, click the component plug-in name in the HBase area, for example, HBase.
- Select the policy whose Policy Name is all - table, column-family, column and click
to edit the policy. - In the Allow Conditions area, select a user from the Select User drop-down list.
Setting the permission for users to create tables
- In HBase Table, specify a table name.
- Click Add Permissions and select Create.
- This user hase the following permissions:
drop table
truncate table
alter table
enable table
flush table
flush region
compact
disable
enable
desc
Setting the permission for users to write data to tables
- Click Add Permissions and select Write.
- The user has the put, delete, append, and incr operation permissions.
Setting the permission for users to read data from tables
- Click Add Permissions and select Read.
- This user hase the get and scan permissions.
Setting the permission for users to manage namespaces or tables
- Click Add Permissions and select Admin.
- The user has the rsgroup, peer, assign and balance operation permissions.
Setting the permission for reading data from or writing data to columns
- In HBase Column-family, specify the column family name.
- Click Add Permissions and select Read and Write.
If a user performs the desc operation in hbase shell, the user must be granted the read permission on the hbase:quota table.
- (Optional) Add the validity period of the policy. Click Add Validity period in the upper right corner of the page, set Start Time and End Time, and select Time Zone. Click Save. To add multiple policy validity periods, click
. To delete a policy validity period, click
. - Click Add to view the basic information about the policy in the policy list. After the policy takes effect, check whether the related permissions are normal.
To disable a policy, click
to edit the policy and set the policy to Disabled.If a policy is no longer used, click
to delete it.
