Submitting a Coordinator Periodic Scheduling Job
This section describes how to submit a job of the periodic scheduling type on the Hue web UI.
Required workflow jobs have been configured before the coordinator task is submitted.
- Access the Hue web UI. For details, see Accessing the Hue Web UI.
- In the navigation tree on the left, click and choose Schedule to open the Coordinator editor.
- On the job editing page, click My Schedule to change the job name.
- Click
to select the workflow to be orchestrated.
- After you select the workflow, set the job execution frequency as prompted. If the workflow to be executed needs to transfer parameters, click + Add parameter to set parameters and click in the upper right corner to save the job.
The time may be several hours different from the local time due to time zone conversion.
- Click in the upper right corner of the editor, set the start value and end value of the time range for executing the scheduled job, and click
to submit the job.
Because the time zone is changed, the difference between the time and the local time may be several hours. For example, in China, the time is 8 hours later than the local time.
