Submitting an Oozie Streaming Job Using Hue
This section describes how to submit an Oozie job of the Streaming type on the Hue web UI.
- Create a workflow. For details, see Creating a Workflow Using Hue.
- On the workflow editing page, select
next to Streaming and drag it to the operation area. - In the Streaming window that is displayed, set Mapper, for example, to /bin/cat. Set Reducer, for example, to /usr/bin/wc. Click Add.
- Click FILE+ to add the files required for running, for example, /user/oozie/share/lib/mapreduce-streaming/hadoop-streaming-xxx.jar and /user/oozie/share/lib/mapreduce-streaming/oozie-sharelib-streaming-5.1.0.jar.
- Click the configuration button
in the upper right corner. On the configuration page that is displayed, click Delete+ to delete a directory, for example, /user/admin/examples/output-data/streaming_workflow. - Click PROPERTIES+ to add the following properties:
- Enter the property name mapred.input.dir in the left box and enter the property value /user/admin/examples/input-data/text in the right box.
- Enter the property name mapred.output.dir in the left box and enter the attribute value /user/admin/examples/output-data/streaming_workflow in the right box.
- Click
in the upper right corner of the Oozie editor.
If you need to modify the job name before saving the job (default value: My Workflow), click the name directly for modification, for example, Streaming-Workflow.
- After the configuration is saved, click
, and submit the job.
After the job is submitted, you can view the related contents of the job, such as the detailed information, logs, and processes, on Hue.
