Submitting an Oozie Hive2 Job Using Hue
This section describes how to submit an Oozie job of the Hive2 type on the Hue web UI.
- Create a workflow. For details, see Creating a Workflow Using Hue.
 - On the workflow editing page, select
 next to HiveServer2 Script and drag it to the operation area. - In the HiveServer2 Script dialog box that is displayed, configure the script path in the HDFS, for example, /user/admin/examples/apps/hive2/script.q, and click Add.
 - Click PARAMETER+ to add input and output parameters.
For example, if the input parameter is INPUT=/user/admin/examples/input-data/table, the output parameter is OUTPUT=/user/admin/examples/output-data/hive2_workflow.
 - Click the configuration button
 in the upper right corner. On the configuration page that is displayed, click Delete + to delete a directory, for example, /user/admin/examples/output-data/hive2_workflow. - Configure JOB XML. The value is the path where the client installation directory/Oozie/oozie-client-*/examples/apps/hive/hive-site.xml is uploaded to the HDFS directory, for example, to the HDFS path /user/admin/examples/apps/hive2/hive-site.xml. You do not need to set HiveServer2 URL and other parameters.
      If the preceding parameters and values are modified, you can query them in Oozie client installation directory//oozie-client-*/conf/hive-site.xml.
 - Click
 in the upper right corner of the Oozie editor.
    If you need to modify the job name before saving the job (default value: My Workflow), click the name directly for modification, for example, Hive2-Workflow.
 - After the configuration is saved, click
, and submit the job.
    After the job is submitted, you can view the related contents of the job, such as the detailed information, logs, and processes, on Hue.
