Help Center/
      MapReduce Service/
        Component Operation Guide (LTS)/
        Using Hive/
        Common Issues About Hive/
      Description of Hive Table Location (Either Be an OBS or HDFS Path)
        Updated on 2024-10-25 GMT+08:00
Question
Can Hive tables be stored in OBS or HDFS?
Answer
- The location of a common Hive table stored on OBS can be set to an HDFS path.
 - In the same Hive service, you can create tables stored in OBS and HDFS, respectively.
 - For a Hive partitioned table stored on OBS, the location of the partition cannot be set to an HDFS path. (For a partitioned table stored on HDFS, the location of the partition cannot be changed to OBS.)
   Parent topic: Common Issues About Hive
