Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using Hive/ Common Issues About Hive/ How Do I Prevent Data Loss Caused by Misoperations of the insert overwrite Statement?
Updated on 2025-11-19 GMT+08:00
Question
How do I prevent key directories from data loss caused by misoperations of the insert overwrite statement?
Answer
During monitoring of key Hive databases, tables, or directories, to prevent data loss caused by misoperations of the insert overwrite statement, configure hive.local.dir.confblacklist in Hive to protect directories.
This configuration item has been configured for directories such as /opt/ and /user/hive/warehouse by default.
The Hive and HDFS components are running properly.
  2. Choose Cluster > Services > Hive > Configurations > All Configurations, and search for the hive.local.dir.confblacklist configuration item.
  1. Add paths of databases, tables, or directories to be protected in the parameter value.
  2. Click Save to save the settings.
