Adjusting Metadata Cache
When HetuEngine accesses the Hive data source, it needs to access the Hive metastore to obtain the metadata information. HetuEngine provides the metadata cache function. When the database or table of the Hive data source is accessed for the first time, the metadata information (database name, table name, table field, partition information, and permission information) of the database or table is cached, the Hive metastore does not need to be accessed again during subsequent access. If the table data of the Hive data source does not change frequently, the query performance can be improved to some extent.
- Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine.
- On the Dashboard tab page that is displayed, find the Basic Information area, and click the link next to HSConsole WebUI.
- On HSConsole, click Data Source. Locate the row that contains the target Hive data source, click Edit in the Operation column, and add custom configurations according to Table 1.
Table 1 Metadata cache parameters Parameter
Default Value
hive.metastore-cache-ttl
Cache duration of the metadata of the co-deployed Hive data source.
0s
hive.metastore-cache-maximum-size
Maximum cache size of the metadata of the co-deployed Hive data source.
10000
hive.metastore-refresh-interval
Interval for refreshing the metadata of the co-deployed Hive data source.
1s
hive.per-transaction-metastore-cache-maximum-size
Maximum cache size of the metadata for each transaction of the co-deployed Hive data source.
1000
- Click OK.
- Restart the HetuEngine service.
Log in to the Manager. On the Dashboard page, click More and select Restart Service to restart the HetuEngine service as prompted.
- Restart the HetuEngine compute instance that is running.
On HSConsole, click Compute Instances, select the running HetuEngine instance, click Restart, and operate as prompted.
