Adjusting HetuEngine Cluster Node Resource Configurations
The default memory size and disk overflow path of HetuEngine are not the best. You need to adjust node resources in the cluster based on the actual service and server configuration of the cluster to achieve the optimal performance.
- Choose Cluster > Services > HetuEngine > Configurations > All Configurations and adjust the cluster node resource parameters by referring to Table 1.
Table 1 Parameters for configuring cluster node resources Parameter
Default Value
Recommended Value
Parameter File
yarn.hetuserver.engine.coordinator.memory
5120
At least 2 GB less than that of yarn.scheduler.maximum-allocation-mb
Memory size used by a Coordinator node
application.properties
yarn.hetuserver.engine.coordinator.number-of-containers
2
2
Number of Coordinator nodes
yarn.hetuserver.engine.coordinator.number-of-cpus
At least two vCores less than yarn.scheduler.maximum-allocation-vcores
CPU vCores used by a Coordinator node
yarn.hetuserver.engine.worker.memory
10240
Memory size used by a worker node
yarn.hetuserver.engine.worker.number-of-containers
2
Adjusted based on application requirements
Number of worker nodes
yarn.hetuserver.engine.worker.number-of-cpus
CPU vCores used by a Worker node
Xmx size in the extraJavaOptions parameter
8 GB
Memory size used by a worker node x 0.8
Maximum available memory of the worker JVM process
worker.jvm.config
query.max-memory-per-node
5 GB
Worker JVM x 0.7
Maximum available memory of a Query node
worker.config.properties
query.max-total-memory-per-node
5 GB
Worker JVM x 0.7
Maximum available memory of a Query + System node
memory.heap-headroom-per-node
3 GB
Worker JVM x 0.3
Maximum available memory of a system heap node
4 GB
Memory size used by a Coordinator node x 0.8
Maximum available memory of the Coordinator JVM process
coordinator.jvm.config
3 GB
Coordinator JVM x 0.7
Maximum memory that can be used for node query
coordinator.config.properties
3 GB
1 GB
Coordinator JVM x 0.3
query.max-memory
7 GB
Sum(query.max-memory-per-node) x 0.7
Maximum available memory of a Query cluster
worker.config.properties/coordinator.config.properties
spiller-spill-path
CONTAINER_ROOT_PATH/tmp/hetuserver/hetuserver-sqlengine/
One or more independent SSDs
Disk output file path
max-spill-per-node
10 GB
Sum(Available space of each node) x 50%
Available disk space for storing output files of all queries on a node
query-max-spill-per-node
10 GB
80% of the available disk space on a node
Available disk space for storing output files of a query on a node
- Click Save.
- Choose Cluster > Services > HetuEngine > More > Restart Service to restart the HetuEngine service for the parameters to take effect.
- Restart the HetuEngine compute instance that is running.
- Log in to FusionInsight Manager as a HetuEngine administrator and choose Cluster > Services > HetuEngine.
- In the displayed Dashboard tab, find the Basic Information area, and click the link next to HSConsole WebUI.
- Click Compute Instances, select the running HetuEngine instance, click Restart, and operate as prompted.
