Importing and Exporting HetuEngine Compute Instance Configurations
On the HetuEngine web UI, you can import or export the instance configuration file and download the instance configuration template.
- Log in to FusionInsight Manager as a user who can access the HetuEngine web UI and choose Cluster > Services > HetuEngine. The HetuEngine service page is displayed.
 - In the Basic Information area on the Dashboard tab page, click the link next to HSConsole WebUI. The HSConsole page is displayed.
 - Click Compute Instance.
- Importing an instance configuration file: Click Import, select an instance configuration file in JSON format from the local PC, and click Open.
       The import and export functions save only the configuration of compute instances. The instance ID, name, start time, end time, and status are not saved. After the import is complete, the information is generated again.
 - Exporting an instance configuration file: Select the instances to be exported and click Export to export the current instance configuration file to the local PC.
