Creating a HetuEngine Permission Role
Before using the HetuEngine service in a cluster that is in security mode, a cluster administrator needs to create a user and grant operation permissions to the user to meet service requirements.
HetuEngine users are classified into administrators and common users. The default HetuEngine administrator group is hetuadmin, and the user group of HetuEngine common users is hetuuser.
- Users associated with the hetuadmin user group can obtain the O&M administrator permissions on the HetuEngine HSConsole web UI and HetuEngine compute instance web UI.
- Users associated with the hetuuser user group can obtain the SQL execution permission. They also have permissions to access the HSConsole web UI, view information about clusters of associated tenants and basic information about all data sources, access the web UI of compute instances, and query and maintain SQL statements of the current user.
If Ranger authentication is enabled, you need to configure the permissions to manage databases, tables, and columns of data sources for a user after it is created. For details, see Adding a Ranger Access Permission Policy for HetuEngine.
Before you use the HetuEngine service, ensure that the tenant to be associated with the HetuEngine user has been planned and created.
Creating a HetuEngine User
Creating a HetuEngine administrator
- Choose System > Permission > User and click Create.
- Enter a username, for example, hetu_admin.
- Set User Type to Human-machine.
- Set Password and Confirm Password.
- In the User Group area, click Add to add the hive, hetuadmin, hadoop, hetuuser, and yarnviewgroup user groups for the user.
- In the Primary Group drop-down list, select hive as the primary group.
- In the Role area, click Add to assign the default, System_administrator, and other desired tenant roles to the user.
- Click OK.
Creating a common HetuEngine user
- Enter a username, for example, hetu_test.
- In the User Group area, click Add to add the hetuuser user group for the user.
- In the Role area, click Add to assign the default or other desired tenant roles to the user.
- Click OK.
