On this page
Show all
Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HDFS/ Common Issues About HDFS/ The HDFS Client Is Unresponsive When the NameNode Is Overloaded for a Long Time
Updated on 2024-10-25 GMT+08:00
Question
When the NameNode node is overloaded (100% of the CPU is occupied), the NameNode is unresponsive. The HDFS clients that are connected to the overloaded NameNode fail to run properly. However, the HDFS clients that are newly connected to the NameNode will be switched to a backup NameNode and run properly.
Answer
The default configuration must be used (as described in Table 1) when the error preceding described occurs: the keep alive mechanism is enabled for the RPC connection between the HDFS client and the NameNode. The keep alive mechanism will keep the HDFS client waiting for the response from server and prevent the connection from being out timed, causing the unresponsiveness of the HDFS client.
Perform the following operations to the unresponsive HDFS client:
  • Leave the HDFS client waiting. Once the CPU usage of the node where NameNode locates drops, the NameNode will obtain CPU resources and the HDFS client will receive a response.
  • If you do not want to leave the HDFS client running, restart the application where the HDFS client locates to reconnect the HDFS client to another idle NameNode.
Procedure:
Configure the following parameters in the client installation path/HDFS/hadoop/etc/hadoop/core-site.xml file on the client.
Table 1 Parameter description
Default Value
ipc.client.ping
If the ipc.client.ping parameter is configured to true, the HDFS client will wait for the response from the server and periodically send the ping message to avoid disconnection caused by tcp timeout.
If the ipc.client.ping parameter is configured to false, the HDFS client will set the value of ipc.ping.interval as the timeout time. If no response is received within that time, timeout occurs.
To avoid the unresponsiveness of HDFS when the NameNode is overloaded for a long time, you are advised to set the parameter to false.
true
ipc.ping.interval
If the value of ipc.client.ping is true, ipc.ping.interval indicates the interval between sending the ping messages.
If the value of ipc.client.ping is false, ipc.ping.interval indicates the timeout time for connection.
To avoid the unresponsiveness of HDFS when the NameNode is overloaded for a long time, you are advised to set the parameter to a large value, for example 900000 (unit ms) to avoid timeout when the server is busy.
60000
