Improving HDFS Write Performance
Improve the HDFS write performance by modifying the HDFS attributes.
   This section applies to MRS 3.x or later.
Navigation path for setting parameters:
On FusionInsight Manager, choose Cluster > Services > HDFS and click Configurations then All Configurations. Enter a parameter name in the search box.
        Parameter  |
        Description  |
        Default Value  |
        dfs.datanode.drop.cache.behind.reads  |
        Specifies whether to enable a DataNode to automatically clear all data in the cache after the data in the cache is transferred to the client.
         This parameter is optional for improving write performance. You can configure it as needed.  |
        false  |
        dfs.client-write-packet-size  |
        Specifies the size of the client write packet. When the HDFS client writes data to the DataNode, the data will be accumulated until a packet is generated. Then, the packet is transmitted over the network. This parameter specifies the size (unit: byte) of the data packet to be transmitted, which can be specified by each job. In the 10-Gigabit network, you can increase the value of this parameter to enhance the transmission throughput.  |
        262144  |
