Using HDFS Mover to Migrate Data
Mover is a new data migration tool whose working mode is similar to that of the HDFS Balancer. Mover can redistribute data in the cluster based on the configured data storage policy.
Use Mover to periodically check whether the specified HDFS file or directory in the HDFS file system meets the preset storage policy. If not, migrate data to make them meet the policy.
This section applies to MRS 3.x or later.
Configuration Description
Go to the All Configurations page of HDFS and enter a parameter name in the search box by referring to Modifying Cluster Service Configuration Parameters.
Parameter |
Description |
Default Value |
dfs.mover.auto.enable |
Specifies whether to enable the data replica migration function. This function supports multiple modes. The default value is false, indicating that this function is disabled. |
false |
dfs.mover.auto.cron.expression |
Specifies the CRON expression for HDFS automatic data migration, and is used to control the start time of data migration. This parameter is valid only when dfs.mover.auto.enable is set to true. The default value is 0 * * * *, indicating that the task is executed on the hour. For details about CRON expression, see Table 2. |
0 * * * * |
dfs.mover.auto.hdfsfiles_or_dirs |
Specifies HDFS file and directory lists that implement automatic replica migration in specified clusters. Multiple values are separated by space. This parameter is valid only when dfs.mover.auto.enable is set to true. |
How to Use
Run the command on the HDFS client to enable the mover function. The command format is as follows:
hdfs mover -p <Full path or directory path of an HDFS file >
The supergroup permission is required for running this command on the client. You can run the command as the system user hdfs who has permission to use the HDFS service. Alternatively, you can create a user with the supergroup permission in the cluster and then run the command.
