Creating HBase Indexes for Data Query
HBase is a distributed storage database of the key-value type. HIndex enables HBase indexing based on specific column values, making the retrieval of data highly efficient and fast.
  • Column families are separated by semicolons (;).
  • Columns and data types must be contained in square brackets ([]).
  • The column data type is specified by using -> after the column name.
  • If the column data type is not specified, the default data type (string) is used.
  • The number sign (#) is used to separate two index details.
  • The following is an optional parameter:
    -Dscan.caching: number of cached rows when the data table is scanned.
    The default value is set to 1000.
  • Indexes are created for a single region to repair damaged indexes. This function is not used to generate new indexes.
Create an HBase HIndex
  1. Install the HBase client. For details, see Using the HBase Client.
  2. Log in to the node where the client is installed as the client installation user.
  3. Go to the client installation directory, for example, /opt/client.
    cd /opt/client
  4. Run the following command to configure environment variables:
    source bigdata_env
  5. If the cluster is in security mode, run the following command to authenticate the user. In normal mode, user authentication is not required.
    kinit Component service user
  6. Run the following command to access HIndex:
    hbase org.apache.hadoop.hbase.hindex.mapreduce.TableIndexer
    Table 1 Common HIndex commands
    Function
    Command
    Add Index
    TableIndexer-Dtablename.to.index=table1-Dindexspecs.to.add='IDX1=>cf1:[q1->datatype],[q2],[q3];cf2:[q1->datatype],[q2->datatype]#IDX2=>cf1:[q5]'
    Create Index
    TableIndexer -Dtablename.to.index=table1 -Dindexnames.to.build='IDX1#IDX2'
    Delete Index
    TableIndexer -Dtablename.to.index=table1 -Dindexnames.to.drop='IDX1#IDX2'
    Disable Index
    TableIndexer -Dtablename.to.index=table1 -Dindexnames.to.disable='IDX1#IDX2'
    Add and Create Index
    TableIndexer -Dtablename.to.index=table1 -Dindexspecs.to.add='IDX1=>cf1:[q1->datatype],[q2],[q3];cf2:[q1->datatype],[q2->datatype]#IDX2=>cf1:[q5]' -Dindexnames.to.build='IDX1'
    Create Index for a Single Region
    TableIndexer -Dtablename.to.index=table1 -Dregion.to.index=regionEncodedName -Dindexnames.to.build='IDX1#IDX2'
    • IDX1: indicates the index name.
    • cf1: indicates the column family name.
    • q1: indicates the column name.
    • datatype: indicates the data type, including String, Integer, Double, Float, Long, Short, Byte and Char.
