Help Center/
MapReduce Service/
Component Operation Guide (LTS)/
Using CarbonData/
CarbonData FAQ/
How to Change the Default Group Name for CarbonData Data Loading?
Updated on 2023-04-28 GMT+08:00
Question
How to change the default group name for CarbonData data loading?
Answer
By default, the group name for CarbonData data loading is ficommon. You can perform the following operation to change the default group name:
- Edit the carbon.properties file.
- Change the value of the key carbon.dataload.group.name as required. The default value is ficommon.
Parent topic: CarbonData FAQ
