REFRESH TABLE
Function
This command is used to register Carbon table data with the Hive metabase.
Syntax
REFRESH TABLE db_name.table_name;
Parameter Description
Table 1 REFRESH TABLE parameters
db_name
Database name. If this parameter is not specified, the current database is selected.
table_name
Table name.
Precautions
  • Before you run this command, copy the schema and data of the source table to the destination database.
  • For the repository of an earlier version, the time zones of the source and destination clusters must be the same.
  • The names of the destination database and the source database must be the same.
  • If you are using aggregate tables, all of them should be copied to the destination database.
  • If the source cluster uses Hive metabase to store the table structure, the refresh does not take effect because the schema file does not exist in the file system.
Example
REFRESH TABLE dbcarbon.productSalesTable;
Response
The source Carbon table data is registered with the Hive metabase.
