CREATE TABLE As SELECT
Function
This command is used to create a CarbonData table by specifying the list of fields along with the table properties.
Syntax
CREATE TABLE [IF NOT EXISTS] [db_name.]table_name STORED AS carbondata [TBLPROPERTIES (key1=val1, key2=val2, ...)] AS select_statement;
Parameter Description
Table 1 CREATE TABLE parameters
db_name
Database name that contains letters, digits, and underscores (_).
table_name
Table name of a database that contains letters, digits, and underscores (_).
STORED AS
Used to store data in CarbonData format.
TBLPROPERTIES
List of CarbonData table properties. For details, see Precautions.
Precautions
N/A
Examples
CREATE TABLE ctas_select_parquet STORED AS carbondata as select * from parquet_ctas_test;
System Response
This example will create a Carbon table from any Parquet table and load all the records from the Parquet table.
