Importing Data to HDFS Using sqoop-shell
Updated on 2024-10-25 GMT+08:00
Taking importing data from SFTP to HDFS as an example, this section introduces how to use the sqoop-shell tool to create and start Loader jobs in the interaction mode and batch mode.
The Loader client has been installed and configured. For details, see Running a Loader Job by Using Commands.
Example for the Interaction Mode
  1. Log in to the node where the Loader client is installed as the user who installs the client.
  2. Run the following command to go to the conf directory of the sqoop-shell tool. For example, if the Loader client installation directory is /opt/client/Loader/, run the following command:
    cd /opt/client/Loader/loader-tools-1.99.3/sqoop-shell/conf
  3. Run the following command to configure authentication information:
    vi client.properties
    server.url=10.0.0.1:21351
    # simple or kerberos
    authentication.type=simple
    # true or false
    use.keytab=true
    authentication.user=
    authentication.password=
    client.principal=hdfs/hadoop@<system domain name>
    # keytab file
    client.keytab.file=./conf/login/hdfs.keytab
    Log in to FusionInsight Manager and choose System > Permission > Domain and Mutual Trust. The value of Local Domain is the current system domain name.
    Table 1 Configuration parameters
    Example Value
    server.url
    Floating IP address and port (21351) for Loader.
    For compatibility, multiple IP addresses and ports can be configured and need to be separated by commas (,). The first IP address and port must be those of Loader (21351). The others can be configured based on service requirements.
    10.0.0.1:21351
    authentication.type
    Login authentication mode.
    • kerberos indicates that the security mode is used and Kerberos authentication is performed. Kerberos authentication provides two authentication modes: the password mode and the keytab file mode.
    • simple indicates that the normal mode is used and Kerberos authentication is not performed.
    kerberos
    authentication.user
    User for login when the normal mode or password authentication is used.
    In the keytab login mode, this parameter does not need to be set.
    bar
    User password for login when the password authentication mode is used.
    In the normal mode or keytab login mode, this parameter does not need to be set.
    The password needs to be encrypted. The encryption method is described as follows:
    1. Go to the directory where encrypt_tool is located. For example, if the Loader client installation directory is /opt/hadoopclient/Loader, run the following command:
      cd /opt/hadoopclient/Loader/loader-tools-1.99.3
    2. Run the following command to encrypt the non-encrypted password. Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
      ./encrypt_tool Unencrypted password
      The obtained encrypted password is used as the value of authentication.password.
      If a non-encrypted password contains special characters, the special characters must be escaped. For example, the dollar sign ($) is a special character and can be escaped using single quotation marks ('). If a non-encrypted password contains single quotation marks, use double quotation marks to escape the single quotation marks. If a non-encrypted password contains double quotation marks, use backslashes (\) to escape the double quotation marks. For details, see the shell escape character rules.
    use.keytab
    Whether to use the keytab mode to log in.
    • true indicates using the keytab file to log in.
    • false indicates using the password to log in.
    true
    client.principal
    User principal for accessing the Loader service when the keytab authentication mode is used.
    In the normal mode or password login mode, this parameter does not need to be set.
    loader/hadoop
    client.keytab.file
    Directory where the used keytab file is located when the keytab authentication mode is used.
    /opt/client/conf/loader.keytab
  4. Run the following command to go to the interaction mode:
    source /opt/client/bigdata_env
    ./sqoop2-shell
    The preceding commands obtain authentication information by reading the configuration file.
    Alternatively, you can also use the password or Kerberos authentication.
    Run the following command to authenticate login using the password mode:
    ./sqoop2-shell -uk false -u username -p encryptedPassword
    Run the following command to authenticate login using the Kerberos mode:
    ./sqoop2-shell -uk true -k user.keytab -s userPrincipal
    Welcome to sqoop client
    Use the username and password authentication mode
    Authentication success.
    Sqoop Shell: Type 'help' or '\h' for help.
    sqoop:000>
  5. Run the following command to view the corresponding ID of the current connector:
    show connector
    The following information is displayed:
    | Id |            Name            |    Version     |                                Class                                 |
    | 1  | generic-jdbc-connector     | 2.0.6-SNAPSHOT | org.apache.sqoop.connector.jdbc.GenericJdbcConnector                 |
    | 2  | ftp-connector              | 2.0.5-SNAPSHOT | org.apache.sqoop.connector.ftp.FtpConnector                          |
    | 3  | hdfs-connector             | 2.0.5-SNAPSHOT | org.apache.sqoop.connector.hdfs.HdfsConnector                        |
    | 4  | oracle-connector           | 2.0.1-SNAPSHOT | org.apache.sqoop.connector.oracle.OracleConnector                    |
    | 5  | mysql-fastpath-connector   | 2.0.1-SNAPSHOT | org.apache.sqoop.connector.mysql.MySqlConnector                      |
    | 6  | sftp-connector             | 2.0.5-SNAPSHOT | org.apache.sqoop.connector.sftp.SftpConnector                        |
    | 7  | oracle-partition-connector | 2.0.6-SNAPSHOT | org.apache.sqoop.connector.oracle.partition.OraclePartitionConnector |
    The preceding information indicates that the SFTP connector ID is 6.
  6. Run the following command to create connectors and enter the specific connector information as prompted:
    create connection -c connector ID
    For example, if the connector ID is 6, run the following command:
    create connection -c 6
    sqoop:000> create connection -c 6
    Creating connection for connector with id 6
    Please fill following values to create new connection object
    Connection configuration
    Sftp server IP: 10.0.0.1
    Sftp server port: 22
    Sftp user name: root
    Sftp password: ************
    Sftp public key:
    New connection was successfully created with validation status FINE and persistent id 20
    sqoop:000>
    The preceding information indicates that the connection ID is 20.
  7. Based on the connection ID, run the following command to create jobs:
    create job -x connection ID -t import
    For example, if the connection ID is 20, run the following command:
    create job -x 20 -t import
    Creating job for connection with id 20
    Please fill following values to create new job object
    File configuration
    Input path: /opt/tempfile
    File split type:
      0 : FILE
      1 : SIZE
    Choose: 0
    Filter type:
      0 : WILDCARD
      1 : REGEX
    Choose: 0
    Path filter: *
    File filter: *
    Encode type:
    Suffix name:
    Compression:
    Output configuration
    Storage type:
      0 : HDFS
      1 : HBASE_BULKLOAD
      2 : HBASE_PUTLIST
      3 : HIVE
    Choose: 0
    File type:
      0 : TEXT_FILE
      1 : SEQUENCE_FILE
      2 : BINARY_FILE
    Choose: 0
    Compression format:
      0 : NONE
      1 : DEFAULT
      2 : DEFLATE
      3 : GZIP
      4 : BZIP2
      5 : LZ4
      6 : SNAPPY
    Choose:
    Output directory: /user/loader/test
    File operate type:
      0 : OVERRIDE
      1 : RENAME
      2 : APPEND
      3 : IGNORE
      4 : ERROR
    Choose: 0
    Throttling resources
    Extractors: 2
    Extractor size:
    New job was successfully created with validation status FINE  and persistent id 85
    sqoop:000>
    The preceding information indicates that the job ID is 85.
  8. Run the following command to start the job:
    start job -j job ID -s
    For example, if the job ID is 85, run the following command:
    start job -j 85 -s
    Displaying the SUCCEEDED information indicates that the job is started successfully.
    Submission details
    Job ID: 85
    Server URL: https://10.0.0.0:21351/loader/
    Created by: admin
    Creation date: 2016-07-20 16:25:38 GMT+08:00
    Lastly updated by: admin
    2016-07-20 16:25:38 GMT+08:00: BOOTING  - Progress is not available
    2016-07-20 16:25:46 GMT+08:00: BOOTING  - 0.00 %
    2016-07-20 16:25:53 GMT+08:00: BOOTING  - 0.00 %
    2016-07-20 16:26:08 GMT+08:00: RUNNING  - 90.00 %
    2016-07-20 16:26:27 GMT+08:00: SUCCEEDED
Example for the Batch Mode
    # true or false
    use.keytab=true
    # keytab file
    Table 2 Configuration parameters
    Example Value
    server.url
    10.0.0.1:21351
    authentication.type
    kerberos
    authentication.user
    bar
    2. Run the following command to encrypt the non-encrypted password:
    use.keytab
    true
    client.principal
    loader/hadoop
    client.keytab.file
  4. Run the following command to go to the directory where the sqoop2-shell script is located and create a text file in the directory, such as batchCommand.sh:
    vi batchCommand.sh
    An example of batchCommand.sh is displayed as follows:
    View parameters
    create connection -c 6 --help
    // Create a connector
    create connection -c 6 -name sftp-connection --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root --connector-connection-sftpPassword xxxxx
    Create a job
    create job -t import -x 20 --connector-file-inputPath /opt/tempfile --connector-file-fileFilter * --framework-output-outputDirectory /user/loader/1 --framework-output-storageType HDFS --framework-throttling-extractorSize 120 --framework-output-fileType TEXT_FILE --connector-file-splitType FILE -name test
    Start a job
    start job -j 85 -s
    xxxxx is the password for the connector.
  5. Run the following command and the sqoop-shell tool will run the preceding commands in sequence:
    ./sqoop2-shell batchCommand.sh
    The commands above authenticate login by reading configuration files. Alternatively, you can attach the authentication information to the command, that is, use the password mode or Kerberos mode to authenticate login.
    ./sqoop2-shell -uk false -u username -p encryptedPassword batchCommand.sh
    ./sqoop2-shell -uk true -k user.keytab -s userPrincipal batchCommand.sh
    sqoop:000> create connection -c 6 --help
    usage: Show connection parameters:
        --connector-connection-sftpPassword <arg>
        --connector-connection-sftpServerIp <arg>
        --connector-connection-sftpServerPort <arg>
        --connector-connection-sftpUser <arg>
        --framework-security-maxConnections <arg>
        --name <arg>
    ===> FINE
    sqoop:000> create connection -c 6 -name sftp-connection --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root --connector-connection-sftpPassword xxxxx
    ===> FINE
    sqoop:000> create job -t import -x 20 --connector-file-inputPath /opt/tempfile --connector-file-fileFilter * --framework-output-outputDirectory /user/loader/1 --framework-output-storageType HDFS --framework-throttling-extractorSize 120 --framework-output-fileType TEXT_FILE --connector-file-splitType FILE -name test
    ===> FINE
    Submission details
    Job ID: 85
    Created by: admin
  6. In the batch mode, the -c parameter can be used to attach a command. sqoop-shell can execute only the attached command at a time.
    Run the following command to create a connection:
    ./sqoop2-shell -c "create connection -c 6 -name sftp-connection --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root --connector-connection-sftpPassword xxxxx"
    You can also use the password mode or Kerberos mode to attach the authentication information to the command.
    ./sqoop2-shell -uk false -u username -p encryptedPassword -c "create connection -c 6 -name sftp-connection --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root --connector-connection-sftpPassword xxxxx"
    ./sqoop2-shell -uk true -k user.keytab -s userPrincipal -c "create connection -c 6 -name sftp-connection --connector-connection-sftpServerIp 10.0.0.1 --connector-connection-sftpServerPort 22 --connector-connection-sftpUser root --connector-connection-sftpPassword xxxxx"
    Displaying the FINE information indicates the connection is created successfully.
    ===> FINE
