On this page
Using loader-backup to Back Up Job Data
Updated on 2024-10-25 GMT+08:00
After a job is created using the Loader WebUI or loader-tool, use loader-backup to back up data.
  • Only Loader jobs of data export support data backup.
  • This tool is an internal Loader interface and is invoked by the upper-layer component HBase. Only the data backup from HDFS to SFTP is supported.
The Loader client has been installed and configured. For details, see Running a Loader Job by Using Commands.
  1. Log in to the node where the client is installed as the user who installs the client. For details, see Running a Loader Job by Using Commands.
  2. Run the following command to go to the directory where the backup.properties file is located. For example, if the Loader client installation directory is /opt/client/Loader/, run the following command:
    cd /opt/client/Loader/loader-tools-1.99.3/loader-backup/conf
  3. Run the following command to modify the configuration parameters of backup.properties. For details about the parameters, see Table 1.
    vi backup.properties
    server.url = 10.0.0.1:21351,10.0.0.2:12000
    authentication.type = kerberos
    authentication.user =
    authentication.password=
    job.jobId = 1
    use.keytab = true
    client.principal = loader/hadoop
    client.keytab = /opt/client/conf/loader.keytab
    Table 1 Configuration parameters
    Example Value
    server.url
    Floating IP address and port (21351) for Loader.
    For compatibility, multiple IP addresses and ports can be configured and need to be separated by commas (,). The first IP address and port must be those of Loader (21351). The others can be configured based on service requirements.
    authentication.type
    Login authentication mode.
    • kerberos indicates that the security mode is used and Kerberos authentication is performed. Kerberos authentication provides two authentication modes: the password mode and the keytab file mode.
    • simple indicates that the normal mode is used and Kerberos authentication is not performed.
    kerberos
    authentication.user
    User for login when the normal mode or password authentication is used.
    In the keytab login mode, this parameter does not need to be set.
    bar
    User password for login when the password authentication mode is used.
    In the normal mode or keytab login mode, this parameter does not need to be set.
    The password needs to be encrypted. The encryption method is described as follows:
    1. Go to the directory where encrypt_tool is located. For example, if the Loader client installation directory is /opt/hadoopclient/Loader, run the following command:
      cd /opt/hadoopclient/Loader/loader-tools-1.99.3
    2. Run the following command to encrypt the non-encrypted password. Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
      ./encrypt_tool Unencrypted password
      The obtained encrypted password is used as the value of authentication.password.
      If a non-encrypted password contains special characters, the special characters must be escaped. For example, the dollar sign ($) is a special character and can be escaped using single quotation marks ('). If a non-encrypted password contains single quotation marks, use double quotation marks to escape the single quotation marks. If a non-encrypted password contains double quotation marks, use backslashes (\) to escape the double quotation marks. For details, see the shell escape character rules.
    job.jobId
    ID of the job whose data is to be backed up.
    Job IDs can be viewed under created jobs on the Loader web UI.
    use.keytab
    Whether to use the keytab mode to log in.
    • true indicates using the keytab file to log in.
    • false indicates using the password to log in.
    true
    client.principal
    User principal for accessing the Loader service when the keytab authentication mode is used.
    In the normal mode or password login mode, this parameter does not need to be set.
    loader/hadoop
    client.keytab
    Directory where the used keytab file is located when the keytab authentication mode is used.
  4. Run the following command to go to the directory where the backup script run.sh is located. For example, if the Loader client installation directory is /opt/hadoopclient/Loader, run the following command:
    cd /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-backup
  5. Run the following command to run the backup script run.sh to back up Loader job data. The system backs up data to a directory at the same layer of the job output directory.
    ./run.sh Backup data input directory
    For example, the backup data input directory is /user/hbase/, and the job output directory is/opt/client/sftp/sftp1. sftp1 acts as a placeholder. Run the following command to back up data to the /opt/client/sftp/hbase directory:
    ./run.sh /user/hbase/
