On this page
schedule-tool Usage Guide
Updated on 2024-10-25 GMT+08:00
Overview
schedule-tool is used to submit jobs of SFTP data sources. You can modify the input path and file filtering criteria before submitting a job. You can modify the output path if the target source is HDFS.
Parameters
Table 1 Configuration parameters of schedule.properties
Example Value
server.url
Floating IP address and port for Loader. The default port is 21351.
For compatibility, multiple IP addresses and ports can be configured and need to be separated by commas (,). The first IP address and port must be those of Loader. The others can be configured based on service requirements.
10.96.26.111:21351,127.0.0.2:21351
authentication.type
Login authentication mode.
  • kerberos indicates that the security mode is used and Kerberos authentication is performed. Kerberos authentication provides two authentication modes: the password mode and the keytab file mode.
  • simple indicates that the normal mode is used and Kerberos authentication is not performed.
kerberos
authentication.user
User for login when the normal mode or password authentication is used.
In the keytab login mode, this parameter does not need to be set.
bar
authentication.password
User password for login when the password authentication mode is used. In the normal mode or keytab login mode, this parameter does not need to be set.
The password needs to be encrypted. The encryption method is described as follows:
  1. Go to the directory where encrypt_tool is located. For example, if the Loader client installation directory is /opt/hadoopclient/Loader, run the following command:
    cd /opt/hadoopclient/Loader/loader-tools-1.99.3
  2. Run the following command to encrypt the non-encrypted password. Commands containing authentication passwords pose security risks. Disable the command recording function (history) before running such commands to prevent information leakage.
    ./encrypt_tool Unencrypted password
    The obtained encrypted password is used as the value of authentication.password.
    If a non-encrypted password contains special characters, the special characters must be escaped. For example, the dollar sign ($) is a special character and can be escaped using single quotation marks ('). If a non-encrypted password contains single quotation marks, use double quotation marks to escape the single quotation marks. If a non-encrypted password contains double quotation marks, use backslashes (\) to escape the double quotation marks. For details, see the shell escape character rules.
use.keytab
Whether to use the keytab mode to log in.
  • true indicates using the keytab file to log in.
  • false indicates using the password to log in.
true
client.principal
User principal for accessing the Loader service when the keytab authentication mode is used.
In the normal mode or password login mode, this parameter does not need to be set.
loader/hadoop.System domain name
You can log in to FusionInsight Manager, choose System > Permission > Domain and Mutual Trust, and view the value of Local Domain, which is the current system domain name.
client.keytab
Directory where the used keytab file is located when the keytab authentication mode is used.
/opt/client/conf/loader.keytab
krb5.conf.file
Directory where the krb5.conf file is located when the keytab authentication mode is used.
/opt/client/conf/krb5.conf
Table 2 Configuration parameters of job.properties
Example Value
job.jobName
Job name.
job1
file.fileName.prefix
File name prefix.
table1
file.fileName.posfix
File name suffix.
.txt
file.filter
File filter, which filters files by matching file names.
  • true indicates that the preceding prefix or suffix is used to match all files in the input path. For details, see the example.
  • false indicates that the preceding prefix or suffix is used to match a file in the input path. For details, see the example.
true
date.day
Number of delayed days, which is matched with the date in the name of an imported file. For example, if the input date is 20160202 and the number of delayed days is 3, files that contain the 20160205 date field in the input path are matched. For details, see schedule-tool Usage Example.
3
file.date.format
Log format included in the name of the file to be imported.
yyyyMMdd
parameter.date.format
Entered date format when a script is invoked, which is usually consistent with file.date.format.
yyyyMMdd
file.format.iscompressed
Whether the file to be imported is a compressed file.
false
storage.type
Storage type. The final type of the file to be imported include HDFS, HBase, and Hive.
HDFS
schedule-tool supports the configuration of multiple jobs at the same time. When multiple jobs are configured at the same time, job.jobName, file.fileName.prefix, and file.fileName.posfix in Table 2 need to be configured with multiple values, and the values need to be separated by commas (,).
Precautions
server.url must be set to a format string of two IP addresses and port numbers, and the IP addresses and ports need to be separated by commas (,).
