On this page
loader-tool Usage Example
Updated on 2024-10-25 GMT+08:00
loader-tool can be used to create, update, query, and delete a connector or job by using a job template or setting parameters.
This section describes how to use loader-tool in the job template mode. The job of importing data from the SFTP server to HDFS is used as an example.
The Loader client has been installed and configured. For details, see Running a Loader Job by Using Commands.
  1. Log in to the node where the client is located as the user who installs the client.
  2. Run the following command to go to the loader-tool directory on the Loader client, for example, /opt/client/Loader/:
    cd /opt/client/Loader/loader-tools-1.99.3/loader-tool/
  3. Run the following command to modify the existing job template. For example, if the job template sftp-to-hdfs.xml already exists in the /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-tool/job-config/, run the following command:
    vi /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-tool/job-config/sftp-to-hdfs.xml
    <root>
    <!-- Database connection information -->
    <sqoop.connection name="vt_sftp_test" type="sftp-connector">
    <connection.sftpServerIp>10.96.26.111</connection.sftpServerIp>
    <connection.sftpServerPort>22</connection.sftpServerPort>
    <connection.sftpUser>root</connection.sftpUser>
    <connection.sftpPassword>Encrypted password</connection.sftpPassword>
    </sqoop.connection>
    <!--Job name, globally unique.-->
    <sqoop.job name="Sftp.to.Hdfs" type="IMPORT" queue="default" priority="NORMAL">
    <data.source connectionName="vt_sftp_test" connectionType="sftp-connector">
    <file.inputPath>/opt/houjt/hive/all</file.inputPath>
    <file.splitType>FILE</file.splitType>
    <file.filterType>WILDCARD</file.filterType>
    <file.pathFilter>*</file.pathFilter>
    <file.fileFilter>*</file.fileFilter>
    <file.encodeType>GBK</file.encodeType>
    <file.suffixName></file.suffixName>
    <file.isCompressive>FALSE</file.isCompressive>
    </data.source>
    <hadoop.source storageType="HDFS" >
    <output.outputDirectory>/user/loader/sftp-to-hdfs</output.outputDirectory>
    <output.fileOprType>OVERRIDE</output.fileOprType>
    <throttling.extractors>3</throttling.extractors>
    <output.fileType>TEXT_FILE</output.fileType>
    </hadoop.source>
    <sqoop.job.trans.file></sqoop.job.trans.file>
    </sqoop.job>
    </root>
    Each Loader job needs to be associated with a connector. Connectors are used to read data from external data sources when data is imported to a cluster and used to write data into external data sources when data is exported from the cluster. In the preceding example, an SFTP data source connector is configured. To configure an SFTP and FTP data source connector, a password needs to be set and encrypted. The password encryption method is described as follows:
    1. Run the following command to go to the loader-tools-1.99.3 directory. For example, if the Loader client installation directory is /opt/hadoopclient/Loader, run the following command:
      cd /opt/hadoopclient/Loader/loader-tools-1.99.3
    2. Run the following command to encrypt the non-encrypted password:
      ./encrypt_tool Unencrypted password
  4. Run the following command to go to the directory where loader-tool is located:
  5. Run the following command to use the lt-ucc tool to create a connector:
    ./bin/lt-ucc -l /opt/client/Loader/loader-tools-1.99.3/loader-tool/job-config/login-info.xml -w /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-tool/job-config/sftp-to-hdfs.xml -a create
    If no error is reported and the following information is displayed, the connector creation task is submitted successfully:
    User login success. begin to execute task.
  6. Run the following command to use the lt-ucj tool to create a job:
    ./bin/lt-ucj -l /opt/client/Loader/loader-tools-1.99.3/loader-tool/job-config/login-info.xml -w /opt/hadoopclient/Loader/loader-tools-1.99.3/loader-tool/job-config/sftp-to-hdfs.xml -a create
    If no error is reported and the following information is displayed, the job creation task is submitted successfully:
  7. Run the following command to use the lt-ctl tool to submit the job:
    ./bin/lt-ctl -l /opt/client/Loader/loader-tools-1.99.3/loader-tool/job-config/login-info.xml -n Sftp.to.Hdfs -a start
    If the following information is displayed, the job is submitted successfully:
    Start job success.
  8. Run the following command to view the job status:
    ./bin/lt-ctl -l /opt/client/Loader/loader-tools-1.99.3/loader-tool/job-config/login-info.xml -n Sftp.to.Hdfs -a status
    Job:Sftp.to.Hdfs
    Status:RUNNING
    Progress: 0.0
