Update Fields Operator
Overview
The Update Fields operator updates fields values when certain conditions are met.
The types supported at present include BIGINT, DECIMAL, DOUBLE, FLOAT, INTEGER, SMALLINT, and VARCHAR. When the type is VARCHAR and the operator is +, strings will be added to the end of field values. The operator - is not supported. For other types, + and - indicate addition and subtraction of values. For all types, = indicates new value assignment.
Input and Output
Input: field
Output: input field
Parameter Description
Table 1 Operator parameters description
Type
Mandatory
Default Value
update field name
Fields to be updated
string
Yes
None
update operator
Operator, which can be +, -, or =.
enum
Yes
update value
Values to be updated
The type is the same as the field type.
No
None
Condition logic connector
Condition logic connector. The options include AND and OR.
enum
Yes
AND
Conditions
Filter condition information:
  • input field name: Names of the input fields. Set this parameter to the names of the fields generated in the previous conversion step.
  • operator: Operator
  • comparative value. You can directly enter the value of a field referenced in the #{Existing field name} format.
map
Yes
None
Data Processing Rule
  • The operator checks whether conditions are met. If yes, the operator updates the field values. If no, the operator does not update the field values.
  • If the field values are digits, the updated values are digits.
  • If the fields are of the string type, the operator - cannot be used.
Example
Use the CSV File Input operator to generate two fields A and B.
The following figure shows the source file.
Configure the Update Fields operator to update a value by adding good to the end of the value if the value is test.
The following figure shows the output result.
