Null Value Conversion
Overview
The null value conversion operator replaces null values with specified values.
Input and Output
- Input: fields with null values
 - Output: original fields with new values
Parameter Description
        Parameter  |
        Description  |
        Node Type  |
        Mandatory  |
        Default Value  |
        Input field name  |
        Names of fields that may have null values. Set this parameter to the names of existing fields.  |
        string  |
        Yes  |
        None  |
        Replace by this value  |
        Specified values for replacing null values.  |
        string  |
        Yes  |
        None  |
Data Processing Rule
When field values are empty, specified values are added.
Example
Use the CSV File Input operator to generate two fields A and B.
The following figure shows the source file.
Configure the null value conversion operator, as shown in the following figure.
After replacement, the values of fields A and B are as follows:
