On this page
HBase Log Overview
Log Description
Log path: The default storage path of HBase logs is /var/log/Bigdata/hbase/Role name.
  • HMaster: /var/log/Bigdata/hbase/hm (run logs) and /var/log/Bigdata/audit/hbase/hm (audit logs)
  • RegionServer: /var/log/Bigdata/hbase/rs (run logs) and /var/log/Bigdata/audit/hbase/rs (audit logs)
  • ThriftServer: /var/log/Bigdata/hbase/ts2 (run logs, ts2 is the instance name) and /var/log/Bigdata/audit/hbase/ts2 (audit logs, ts2 is the instance name)
Log archive rule: The automatic log compression and archiving function of HBase is enabled. By default, when the size of a log file exceeds 30 MB, the log file is automatically compressed. The naming rule of a compressed log file is as follows: <Original log name>-<yyyy-mm-dd_hh-mm-ss>.[ID].log.zip A maximum of 20 latest compressed files are reserved. The number of compressed files can be configured on the Manager portal.
Table 1 HBase log list
Type
Name
Run logs
hbase-<SSH_USER>-<process_name>-<hostname>.log
HBase system log that records the startup time, startup parameters, and most logs generated when the HBase system is running.
hbase-<SSH_USER>-<process_name>-<hostname>.out
Log that records the HBase running environment information.
<process_name>-<SSH_USER>-<DATE>-<PID>-gc.log
Log that records HBase junk collections.
checkServiceDetail.log
Log that records whether the HBase service starts successfully.
hbase.log
Log generated when the HBase service health check script and some alarm check scripts are executed.
sendAlarm.log
Log that records alarms reported after execution of HBase alarm check scripts.
hbase-haCheck.log
Log that records the active and standby status of HMaster
stop.log
Log that records the startup and stop processes of HBase.
Audit logs
hbase-audit-<process_name>.log
Log that records HBase security audit.
Log Level
Table 2 describes the log levels supported by HBase. The priorities of log levels are FATAL, ERROR, WARN, INFO, and DEBUG in descending order. Logs whose levels are higher than or equal to the specified level are printed. The number of printed logs decreases as the specified log level increases.
Table 2 Log levels
Level
FATAL
Logs of this level record fatal error information about the current event processing that may result in a system crash.
ERROR
Logs of this level record error information about the current event processing, which indicates that system running is abnormal.
WARN
Logs of this level record abnormal information about the current event processing. These abnormalities will not result in system faults.
INFO
Logs of this level record normal running status information about the system and events.
DEBUG
Logs of this level record the system information and system debugging information.
To modify log levels, perform the following operations:
  1. Go to the All Configurations page of the HBase service. For details, see Modifying Cluster Service Configuration Parameters.
  2. On the left menu bar, select the log menu of the target role.
  3. Select a desired log level.
  4. Save the configuration. In the displayed dialog box, click OK to make the configurations take effect.
    The configurations take effect immediately without the need to restart the service.
Log Formats
The following table lists the HBase log formats.
Table 3 Log formats
Type
Component
Format
Example
Run logs
HMaster
<yyyy-MM-dd HH:mm:ss,SSS>|<Log Level>|<Thread that generates the log>|<Message in the log>|<Location of the log event>
2020-01-19 16:04:53,558 | INFO | main | env:HBASE_THRIFT_OPTS= | org.apache.hadoop.hbase.util.ServerCommandLine.logProcessInfo(ServerCommandLine.java:113)
RegionServer
2020-01-19 16:05:18,589 | INFO | regionserver16020-SendThread(linux-k6da:2181) | Client will use GSSAPI as SASL mechanism. | org.apache.zookeeper.client.ZooKeeperSaslClient$1.run(ZooKeeperSaslClient.java:285)
ThriftServer
2020-02-16 09:42:55,371 | INFO | main | loaded properties from hadoop-metrics2.properties | org.apache.hadoop.metrics2.impl.MetricsConfig.loadFirst(MetricsConfig.java:111)
Audit logs
HMaster
2020-02-16 09:42:40,934 | INFO | master:linux-k6da:16000 | Master: [master:linux-k6da:16000] start operation called. | org.apache.hadoop.hbase.master.HMaster.run(HMaster.java:581)
RegionServer
2020-02-16 09:42:51,063 | INFO | main | RegionServer: [regionserver16020] start operation called. | org.apache.hadoop.hbase.regionserver.HRegionServer.startRegionServer(HRegionServer.java:2396)
ThriftServer
2020-02-16 09:42:55,512 | INFO | main | thrift2 server start operation called. | org.apache.hadoop.hbase.thrift2.ThriftServer.main(ThriftServer.java:421)
