Configuring a Secure Transmission Protocol for Kafka Data
This section applies to MRS 3.x or later.
Brief Introduction to Kafka APIs
- Producer API
Indicates the API defined in org.apache.kafka.clients.producer.KafkaProducer. When kafka-console-producer.sh is used, the API is used by default.
- Consumer API
Indicates the API defined in org.apache.kafka.clients.consumer.KafkaConsumer. When kafka-console-consumer.sh is used, the API is used by default.
In MRS 3.x or later, Kafka no longer support old Producer or Consumer APIs.
Protocol Description for Accessing Kafka
The protocols used to access Kafka are as follows: PLAINTEXT, SSL, SASL_PLAINTEXT, and SASL_SSL.
When Kafka service is started, the listeners using the PLAINTEXT and SASL_PLAINTEXT protocols are started. You can set ssl.mode.enable to true in Kafka service configuration to start listeners using SSL and SASL_SSL protocols. The following table describes the four protocols:
For details about how to view or configure parameters, see Modifying Cluster Service Configuration Parameters.
Protocol |
Description |
Default Port |
PLAINTEXT |
Supports plaintext access without authentication. |
Obtain the value of port. The default value is 9092 |
SASL_PLAINTEXT |
Supports plaintext access with Kerberos authentication. |
Obtain the value of sasl.port. The default value is 21007 |
SSL |
Supports SSL-encrypted access without authentication. |
Obtain the value of ssl.port. The default value is 9093 |
SASL_SSL |
Supports SSL-encrypted access with Kerberos authentication. |
Obtain the value of sasl-ssl.port. The default value is 21009 |
ACL Settings for a Topic
To view and set topic permission information, run the kafka-acls.sh script on the Linux client. For details, see Kafka User Permissions.
Use of Kafka APIs in Different Scenarios
- Scenario 1: accessing the topic with an ACL
Used API
User Group
Client Parameter
Server Parameter
Accessed Port
API
Users need to meet one of the following conditions:
- Assigned the System_administrator role
- In the kafkaadmin group
- In the kafkasuperuser group
- In the kafka group and be authorized
security.inter.broker.protocol=SASL_PLAINTEXT sasl.kerberos.service.name = kafka
sasl.port (The default number is 21007.)
security.protocol=SASL_SSL sasl.kerberos.service.name = kafka
Set ssl.mode.enable to true.
sasl-ssl.port (The default number is 21009.)
- Scenario 2: accessing the topic without an ACL
Used API
User Group
Client Parameter
Server Parameter
Accessed Port
API
security.protocol=SASL_PLAINTEXT sasl.kerberos.service.name = kafka
Users are in the kafka group.
Set allow.everyone.if.no.acl.found to true.
NOTE:In normal mode, the server parameter allow.everyone.if.no.acl.found does not need to be modified.
- Set allow.everyone.if.no.acl.found to true.
- Set ssl.mode.enable to true.
security.protocol=PLAINTEXT
port (The default number is 9092.)
security.protocol=SSL
ssl.port (The default number is 9063.)
