On this page
Improving HBase Real-Time Read Efficiency
Scenarios where the performance of reading HBase data needs to be improved.
The get or scan interface of HBase has been invoked and data is read in real time from HBase.
  • Data reading server tuning
    Parameter portal: Log in to FusionInsight Manager and choose Cluster > Services > Configurations > All Configurations. The All Configurations page is displayed, modify related parameter values to improve the HBase data read performance.
    Table 1 Configuration items that affect real-time data reading
    Default Value
    GC_OPTS
    You can increase HBase memory to improve HBase performance because read and write operations are performed in HBase memory.
    HeapSize and NewSize need to be adjusted. When you adjust HeapSize, set Xms and Xmx to the same value to avoid performance problems when JVM dynamically adjusts HeapSize. Set NewSize to 1/8 of HeapSize.
    • HMaster: If HBase clusters enlarge and the number of Regions grows, properly increase the GC_OPTS parameter value of the HMaster.
    • RegionServer: A RegionServer needs more memory than an HMaster. If sufficient memory is available, increase the HeapSize value.
    When the value of HeapSize for the active HMaster is 4 GB, the HBase cluster can support 100,000 Regions. Empirically, each time 35,000 Regions are added to the cluster, the value of HeapSize must be increased by 2 GB. It is recommended that the value of HeapSize for the active HMaster not exceed 32 GB.
    • HMaster
      -server -Xms4G -Xmx4G -XX:NewSize=512M -XX:MaxNewSize=512M -XX:MetaspaceSize=128M -XX:MaxMetaspaceSize=512M -XX:+UseConcMarkSweepGC -XX:+CMSParallelRemarkEnabled -XX:CMSInitiatingOccupancyFraction=65 -XX:+PrintGCDetails -Dsun.rmi.dgc.client.gcInterval=0x7FFFFFFFFFFFFFE -Dsun.rmi.dgc.server.gcInterval=0x7FFFFFFFFFFFFFE -XX:-OmitStackTraceInFastThrow -XX:+PrintGCTimeStamps -XX:+PrintGCDateStamps -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=10 -XX:GCLogFileSize=1M
    • Region Server
      -server -Xms6G -Xmx6G -XX:NewSize=1024M -XX:MaxNewSize=1024M -XX:MetaspaceSize=128M -XX:MaxMetaspaceSize=512M -XX:+UseConcMarkSweepGC -XX:+CMSParallelRemarkEnabled -XX:CMSInitiatingOccupancyFraction=65 -XX:+PrintGCDetails -Dsun.rmi.dgc.client.gcInterval=0x7FFFFFFFFFFFFFE -Dsun.rmi.dgc.server.gcInterval=0x7FFFFFFFFFFFFFE -XX:-OmitStackTraceInFastThrow -XX:+PrintGCTimeStamps -XX:+PrintGCDateStamps -XX:+UseGCLogFileRotation -XX:NumberOfGCLogFiles=10 -XX:GCLogFileSize=1M
    hbase.regionserver.handler.count
    Indicates the number of requests that RegionServer can process concurrently. If the parameter is set to an excessively large value, threads will compete fiercely. If the parameter is set to an excessively small value, requests will be waiting for a long time in RegionServer, reducing the processing capability. You can add threads based on resources.
    It is recommended that the value be set to 100 to 300 based on the CPU usage.
    200
    hfile.block.cache.size
    HBase cache sizes affect query efficiency. Set cache sizes based on query modes and query record distribution. If random query is used to reduce the hit ratio of the buffer, you can reduce the buffer size.
    When offheap is disabled, the default value is 0.25. When offheap is enabled, the default value is 0.1.
    If read and write operations are performed at the same time, the performance of the two operations affects each other. If flush and compaction operations are frequently performed due to data writes, a large number of disk I/O operations are occupied, affecting read performance. If a large number of compaction operations are blocked due to write operations, multiple HFiles exist in the region, affecting read performance. Therefore, if the read performance is unsatisfactory, you need to check whether the write configurations are proper.
  • Data reading client tuning
    When scanning data, you need to set caching (the number of records read from the server at a time. The default value is 1.). If the default value is used, the read performance will be extremely low.
    If you do not need to read all columns of a piece of data, specify the columns to be read to reduce network I/O.
    If you only need to read the row key, add a filter (FirstKeyOnlyFilter or KeyOnlyFilter) that only reads the row key.
  • Data table reading design optimization
    Set the following table parameters in the HBase shell to improve the performance of reading HBase data in real time.
    Table 2 Parameters affecting real-time data reading
    Default Value
    COMPRESSION
    The compression algorithm compresses blocks in HFiles. For compressible data, configure the compression algorithm to efficiently reduce disk I/Os and improve performance.
    Some data cannot be efficiently compressed. For example, a compressed figure can hardly be compressed again. The common compression algorithm is SNAPPY, because it has a high encoding/decoding speed and acceptable compression rate.
    NONE
    BLOCKSIZE
    Different block sizes affect HBase data read and write performance. You can configure sizes for blocks in an HFile. Larger blocks have a higher compression rate. However, they have poor performance in random data read, because HBase reads data in a unit of blocks.
    Set the parameter to 128 KB or 256 KB to improve data write efficiency without greatly affecting random read performance. The unit is byte.
    65536
    DATA_BLOCK_ENCODING
    Encoding method of the block in an HFile. If a row contains multiple columns, set FAST_DIFF to save data storage space and improve performance.
    NONE
