Help Center/ MapReduce Service/ Component Operation Guide (LTS)/ Using HBase/ HBase O&M Management/ Configuring Region In Transition Recovery Chore Service
Updated on 2025-07-16 GMT+08:00
In a faulty environment, there are possibilities that a region may be stuck in transition for longer duration due to various reasons like slow region server response, unstable network, ZooKeeper node version mismatch. During region transition, client operation may not work properly as some regions will not be available.
Enabling Region Transition Recovery
A chore service should be scheduled at HMaster to identify and recover regions that stay in the transition state for a long time.
Log in to FusionInsight Manager and choose Cluster > Services > HBase > Configurations. The following table lists the parameters for enabling this function.
Table 1 Parameters
Default Value
hbase.region.assignment.auto.recovery.enabled
Configuration parameter used to enable/disable the region assignment recovery thread feature.
true
