Allowing Only the Hive Administrator to Create Databases and Create Tables in the Default Database
By default, users who have the permission to create Hive tables can create databases and tables in the default database on the Hive client. You can also configure Hive to allow only the Hive administrator to create databases and tables in the default database. Other users can use the databases only after being authorized by the Hive administrator.
Notes and Constraints
- This section applies only to clusters with Kerberos authentication enabled.
 - This section applies only to the scenario where Ranger authentication is not enabled for Hive.
 - After this function is enabled, common users are not allowed to create a database or create a table in the default database. Exercise caution when enabling this function.
 - The non-administrator users are not allowed to perform operations such as database creation, table script migration, and metadata re-creation.
- Log in to FusionInsight Manager, choose Cluster > Services > Hive, click Configurations, and click All Configurations.
 - Choose HiveServer(Role) > Customization, add a customized parameter to the hive-site.xml parameter file, and set Name to hive.allow.only.admin.create and Value to true.The configuration ensures that only the Hive administrator can create databases and tables in the default database.
 - Click Save to save the settings. Click Instances, select all Hive instances, click More then Restart Instance, enter the user password, and click OK to restart all Hive instances.
 - Determine whether to enable this function on the Spark/Spark2x client.
- If yes, go to 5.
 - If no, no further action is required.
- Choose SparkResource2x > Customization, add a customized parameter to the hive-site.xml parameter file, set Name to hive.allow.only.admin.create and Value to true. Then, choose JDBCServer2x > Customization and repeat the preceding operations to add the customized parameter.
 - Click Save to save the settings. Click Instances, select all Spark2x instances, click More and then Restart Instance, enter the user password, and click OK to restart all instances.
 - Download and install the Spark/Spark2x client again.
 - The following describes how to enable this function on the Hive client.
- Log in to the node where the client is installed as the client installation user.
 - Go to the client installation directory, configure environment variables, and authenticate the user.
- Go to the client installation directory.
cd /opt/hadoopclient
 - Configure environment variables.
source bigdata_env
 - Authenticate the user. The user must have the permission to create Hive tables. Skip this step if Kerberos authentication is disabled for the cluster (in normal mode).
kinit Component service userExample:
kinit test
 - Log in to the Hive client.
beeline
 - Create a database and create a table in the default database.
Create a database.
create database test;
After the command is executed, the following error message is displayed, indicating that only users with administrator permissions can create databases:
Figure 1 Error message reported when a database is created
      Create a table.create table test(name string);After the command is executed, the following error message is displayed, indicating that only users with administrator permissions can create tables in the default database:
Figure 2 Error reported during table creation
       - Bind the role with the Hive administrator permission to the user. For details, see Creating a Hive User and Binding the User to a Role.
 - Create a database or create a table in the default database on the Hive client.
