Updated on 2025-11-13 GMT+08:00
HDFS Log Overview
Log Description
Log path: The default path of HDFS logs is /var/log/Bigdata/hdfs/Role name.
  • NameNode: /var/log/Bigdata/hdfs/nn (run logs) and /var/log/Bigdata/audit/hdfs/nn (audit logs)
  • DataNode: /var/log/Bigdata/hdfs/dn (run logs) and /var/log/Bigdata/audit/hdfs/dn (audit logs)
  • ZKFC: /var/log/Bigdata/hdfs/zkfc (run logs) and /var/log/Bigdata/audit/hdfs/zkfc (audit logs)
  • JournalNode: /var/log/Bigdata/hdfs/jn (run logs) and /var/log/Bigdata/audit/hdfs/jn (audit logs)
  • Router: /var/log/Bigdata/hdfs/router (run logs) and /var/log/Bigdata/audit/hdfs/router (audit logs)
  • HttpFS: /var/log/Bigdata/hdfs/httpfs (run logs) and /var/log/Bigdata/audit/hdfs/httpfs (audit logs)
Log archive rule: The automatic HDFS log compression function is enabled. By default, when the size of logs exceeds 100 MB, logs are automatically compressed into a log file named in the following format: <Original log file name>-<yyyy-mm-dd_hh-mm-ss.[ID].log.zip. A maximum of 100 latest compressed files are reserved. The number of compressed files can be configured on Manager.
Table 1 HDFS log list
Type
Name
Run log
hadoop-<SSH_USER>-<process_name>-<hostname>.log
HDFS system log, which records most of the logs generated when the HDFS system is running.
hadoop-<SSH_USER>-<process_name>-<hostname>.out
Log that records the HDFS running environment information.
hadoop.log
Log that records the operation of the Hadoop client.
hdfs-period-check.log
Log that records scripts that are executed periodically, including automatic balancing, data migration, and JournalNode data synchronization detection.
<process_name>-<SSH_USER>-<DATE>-<PID>-gc.log
Garbage collection log file
postinstallDetail.log
Work log before the HDFS service startup and after the installation.
hdfs-service-check.log
Log that records whether the HDFS service starts successfully.
hdfs-set-storage-policy.log
Log that records the HDFS data storage policies.
cleanupDetail.log
Log that records the cleanup logs about the uninstallation of the HDFS service.
prestartDetail.log
Log that records cluster operations before the HDFS service startup.
hdfs-recover-fsimage.log
Recovery log of the NameNode metadata.
datanode-disk-check.log
Log that records the disk status check during the cluster installation and use.
hdfs-availability-check.log
Log that checks whether the HDFS service is available.
hdfs-backup-fsimage.log
Backup log of the NameNode metadata.
startDetail.log
Log that records HDFS service startup details
hdfs-blockplacement.log
Log that records the placement policy of HDFS blocks.
upgradeDetail.log
Upgrade logs.
hdfs-clean-acls-java.log
Log that records the clearing of deleted roles' ACL information by HDFS.
hdfs-haCheck.log
Run log that checks whether the NameNode in active or standby state has obtained scripts.
<process_name>-jvmpause.log
Log that records JVM pauses during process running.
hadoop-<SSH_USER>-balancer-<hostname>.log
Run log of HDFS automatic balancing.
hadoop-<SSH_USER>-balancer-<hostname>.out
Log that records information of the environment where HDFS executes automatic balancing.
hdfs-switch-namenode.log
Run log that records the HDFS active/standby switchover
hdfs-router-admin.log
Run log of mount table management operations
threadDump-<DATE>.log
Instance process stack log
Tomcat logs
hadoop-omm-host1.out, httpfs-catalina.<DATE>.log, httpfs-host-manager.<DATE>.log, httpfs-localhost.<DATE>.log, httpfs-manager.<DATE>.log, localhost_access_web_log.log
Tomcat run logs
Audit log
hdfs-audit-<process_name>.log
ranger-plugin-audit.log
Audit log that records the HDFS operations (such as creating, deleting, modifying and querying files).
SecurityAuth.audit
HDFS security audit log.
Log Level
Table 2 lists the log levels supported by HDFS. The log levels include FATAL, ERROR, WARN, INFO, and DEBUG. Logs of which the levels are higher than or equal to the set level will be printed by programs. The higher the log level is set, the fewer the logs are recorded.
Table 2 Log levels
Level
FATAL
Indicates the critical error information about system running.
ERROR
Indicates the error information about system running.
WARN
Indicates that the current event processing exists exceptions.
INFO
Indicates that the system and events are running properly.
DEBUG
Indicates the system and system debugging information.
To modify log levels, perform the following operations:
  1. Go to the All Configurations page of HDFS by referring to Modifying Cluster Service Configuration Parameters.
  2. On the left menu bar, select the log menu of the target role.
  3. Select a desired log level.
  4. Save the configuration. In the displayed dialog box, click OK to make the configurations take effect.
    The configurations take effect immediately without restarting the service.
Log Formats
The following table lists the HDFS log formats.
Table 3 Log formats
Type
Format
Example
Run log
<yyyy-MM-dd HH:mm:ss,SSS>|<Log level>|<Name of the thread that generates the log>|<Message in the log>|<Location where the log event occurs>
20xx-01-26 18:43:42,840 | INFO | IPC Server handler 40 on 8020 | Rolling edit logs | org.apache.hadoop.hdfs.server.namenode.FSEditLog.rollEditLog(FSEditLog.java:1096)
Audit log
20xx-01-26 18:44:42,607 | INFO | IPC Server handler 32 on 8020 | allowed=true ugi=hbase (auth:SIMPLE) ip=/10.177.112.145 cmd=getfileinfo src=/hbase/WALs/hghoulaslx410,16020,1421743096083/hghoulaslx410%2C16020%2C1421743096083.1422268722795 dst=null perm=null | org.apache.hadoop.hdfs.server.namenode.FSNamesystem$DefaultAuditLogger.logAuditMessage(FSNamesystem.java:7950)
Helpful Links
