Introduction to HBase Local Secondary Indexes
HBase is a distributed storage database of the Key-Value type. Data in tables is sorted by dictionary based on row keys. If you query data by specifying a row key or scan data in a specific row key range, HBase can help you quickly locate the data to be read. In most cases, you need to query data whose column value is XXX. HBase provides the filter function to enable you to query data with a specific column value. All data is scanned in the sequence of row keys and is matched with the specific column value until the required data is found. To obtain the required data, the filter will scan some unnecessary data. As a result, the filter function cannot meet the requirements for high-performance, frequent queries.
HBase HIndex is designed to address these issues. HBase HIndex provides HBase with the capability of indexing based on specific column values, making queries faster.
- Rolling upgrade is not supported for index data.
- Composite index: You must add or delete all columns that participate in composite indexes. Otherwise, the data may be inconsistent.
- You should not explicitly configure any split policy to a data table where an index has been created.
- The mutation operations are not supported, such as increment and append.
- Index of the column with maxVersions greater than 1 is not supported.
- The value size of a column for which an index is added cannot exceed 32 KB.
- When the user data is deleted because TTL of the column family is invalid, the corresponding index data will not be deleted immediately. The index data will be deleted during major compaction.
- After an index is created, the TTL of the user column family must not be changed.
- If the TTL of the column family is changed to a larger value after an index is created, delete the index and create one again. Otherwise, some generated index data may be deleted before the deletion of user data.
- If the TTL of the column family is changed to a smaller value after an index is created, the index may be deleted after the deletion of user data.
- After disaster recovery is enabled for HBase tables, a secondary index is created in the active cluster and index table changes are not automatically synchronized to the standby cluster. To implement disaster recovery in this case, perform the following operations:
- After the secondary index is created in the active table, create a secondary index with the same schema and name using the same method in the standby cluster.
- In the active cluster, manually set REPLICATION_SCOPE of the index column family (default value: d) to 1.
Configuring the HBase Local Secondary Index
- Log in to the MRS console, click the cluster name in the existing cluster list, and choose Components.
- In the component list, choose HBase > Service Configuration. In the drop-down list, switch Basic Configuration to All Configurations. The All Configurations page is displayed.
- View parameters on the HBase configurations page.
Table 1 Parameters related to HBase Index Navigation Path
Default Value
HMaster > System
hbase.coprocessor.master.classes
org.apache.hadoop.hbase.hindex.server.master.HIndexMasterCoprocessor,com.xxx.hadoop.hbase.backup.services.RecoveryCoprocessor,org.apache.ranger.authorization.hbase.RangerAuthorizationCoprocessor,org.apache.hadoop.hbase.security.access.ReadOnlyClusterEnabler,org.apache.hadoop.hbase.rsgroup.RSGroupAdminEndpoint
This coprocessor is used to handle Master-level operations after the HIndex function is enabled, for example, creating an index meta table, adding an index, and deleting an index, a table, and index metadata.
RegionServer > RegionServer
hbase.coprocessor.regionserver.classes
org.apache.hadoop.hbase.hindex.server.regionserver.HIndexRegionServerCoprocessor,org.apache.hadoop.hbase.JMXListener,org.apache.ranger.authorization.hbase.RangerAuthorizationCoprocessor
This coprocessor is used to handle the operations that the Master delivers to RegionServer after the HIndex function is enabled.
hbase.coprocessor.region.classes
org.apache.hadoop.hbase.hindex.server.regionserver.HIndexRegionCoprocessor,org.apache.hadoop.hbase.security.token.TokenProvider,com.xxx.hadoop.hbase.backup.services.RecoveryCoprocessor,org.apache.ranger.authorization.hbase.RangerAuthorizationCoprocessor,org.apache.hadoop.hbase.security.access.SecureBulkLoadEndpoint,org.apache.hadoop.hbase.security.access.ReadOnlyClusterEnabler,org.apache.hadoop.hbase.coprocessor.MetaTableMetrics
This coprocessor is used to operate data in the Region after the HIndex function is enabled.
- The preceding default values need to be configured after the HBase HIndex function is enabled. In MRS clusters that support the HBase HIndex function, the values have been configured by default.
- Ensure that the master parameter is configured on HMaster and the region and regionserver parameters are configured on RegionServer.
Interfaces Related to HBase Local Secondary Indexes
The APIs that use HIndex are in the org.apache.hadoop.hbase.hindex.client.HIndexAdmin class. The following table describes the related APIs.
Querying Data Based on HBase Local Secondary Indexes
You can use a filter to query data in a user table with an index. The query result of a user table with a single or combination index is the same as that of a table without an index, but the table with an index provides higher data query performance than the table without an index.
The index usage rules are as follows:
- Scenario 1: A single index is created for one or more columns.
- When this column is used for AND or OR query filtering, an index can improve query performance.
Example: Filter_Condition(IndexCol1)AND / OR Filter_Condition(IndexCol2)
- When you use Index Column AND Non-Index Column for filtering in the query, the index can improve query performance.
Example: Filter_Condition(IndexCol1)AND Filter_Condition(IndexCol2)AND Filter_Condition(NonIndexCol1)
- When you use Index Column OR Non-Index Column for filtering in the query but do not use an index, query performance will not be improved.
Example: Filter_Condition(IndexCol1)AND / OR Filter_Condition(IndexCol2) OR Filter_Condition(NonIndexCol1)
- Scenario 2: A combination index is created for multiple columns.
- When the columns to be queried are all or part of the combination index and have the same order as the combination index, using the index improves query performance.
For example, create a combination index for C1, C2, and C3.
- The index takes effect in the following situations:
Filter_Condition(IndexCol1)AND Filter_Condition(IndexCol2)AND Filter_Condition(IndexCol3)
FILTER_CONDITION(IndexCol1)
- The index does not take effect in the following situations:
Filter_Condition(IndexCol1)AND Filter_Condition(IndexCol3)
FILTER_CONDITION(IndexCol2)
FILTER_CONDITION(IndexCol3)
Examples:
Filter_Condition(IndexCol1)AND Filter_Condition(NonIndexCol1)
Examples:
Filter_Condition(IndexCol1)OR Filter_Condition(NonIndexCol1)
(Filter_Condition(IndexCol1)AND Filter_Condition(IndexCol2))OR(Filter_Condition(NonIndexCol1))
- When multiple columns are used for query, you can specify a value range for only the last column in the combination index and set other columns to specified values
For example, create a combination index for C1, C2, and C3. In a range query, only the value range of C3 can be set. The filter criteria are "C1 = XXX, C2 = XXX, and C3 = Value range."
HBase Local Secondary Index Query Policy Selection
Use SingleColumnValueFilter or SingleColumnRangeFilter. It will provide the definite value column_family:qualifierpair (called col1) in filter criteria.
If col1 is the first index column in the table, any index in the table can be a candidate index used during the query. The following provides an example:
If there is an index on col1, the index can be used as a candidate index because col1 is the first and the only column of the index. If there is another index on col1 and col2, you can consider this index as a candidate index because col1 is the first column in the index list. However, if there is an index on col2 and col1, this index cannot be used as a candidate index because the first column in the index list is not col1.
The most suitable method to use the index now is that when there are multiple candidate indexes, select the most suitable index for scanning data.
You can use the following solutions to learn how to select the best index policy.
- It is better to fully match.
Scenario: There are two indexes available, one for col1&col2 and the other for col1.
In this scenario, the second index is better than the first one, because it scans less index data.
- If there are multiple candidate multi-column indexes, select an index with fewer index columns.
Scenario: There are two indexes available, one for col1&col2 and the other for col1&col2&col3.
In this case, you had better use the index on col1&col2, because it scans less index data.
- During a query based on an index, the index state must be ACTIVE. You can call the listIndices() API to view the index state.
- To query the correct data based on the index, ensure the consistency between index data and user data.
- Run the following command to perform a complex query on the HBase shell client (assuming that an index has been created for the specified column):
scan 'tablename', {FILTER => "SingleColumnValueFilter(family, qualifier, compareOp, comparator, filterIfMissing, latestVersionOnly)"}
Example: scan 'test', {FILTER => "SingleColumnValueFilter('info', 'age', =, 'binary:26', true, true)"}
In the preceding scenario, if you want to save the row where no column is found in the result, you should not create any index in any such column, because if the column to be queried does not exist, the row will be filtered out when SCVF is used to scan the index columns. When the SCVF whose filterIfMissingset is false (default value) scans non-index columns, rows where no column is queried will also be returned in the result. Therefore, to avoid inconsistent query results, you are advised to set filterIfMissing to true after creating SCVF for the index column.
- Run the following command on the hbase shell client to view the index data created for user data:
scan 'tablename', {ATTRIBUTES => {'FETCH_INDEX_DATA' => 'true'}}
