OBS Resources
A resource is an object that exists within a service. OBS resources include buckets and objects. You can select these resources by specifying their paths.
Resource Type |
Resource Name |
Path |
bucket |
bucket |
[Format] obs:*:*:bucket:bucket name [Notes] For bucket resources, IAM automatically generates the prefix of the resource path: obs:*:*:bucket: For the path of a specific bucket, add the bucket name to the end. You can also use an asterisk * to indicate any bucket. Example: obs:*:*:bucket:* |
object |
object |
[Format] obs:*:*:object:bucket name/object name [Notes] For object resources, IAM automatically generates the prefix of the resource path: obs:*:*:object: For the path of a specific object, add the bucket name/object name to the end. You can also use an asterisk * to any object in a bucket. Example: obs:*:*:object:my-bucket/my-object/*: indicates any object in the my-object directory of the my-bucket bucket. |
