- What's New
- Function Overview
- Product Notices
- Billing
- Getting Started
User Guide
- Accessing OBS
- Storage Class
- Bucket Management
- Object Management
- Permissions Control
- Data Security
- Disaster Recovery and Backup
- Domain Name Management
- Data Management
Data Processing
Image Processing
- Overview
- Notes and Constraints
- Basic Concepts
- Using Image Processing on OBS Console
- Using Image Processing with APIs
- Getting Information About an Image
- Getting the Average RGB Value of an Image
- Setting Image Effects
- Resizing Images
- Rotating Images
- Cropping Images
- Watermarking Images
- Converting Formats and Interlacing Images
- Changing Image Quality
- Slimming Images
- Image Processing Persistency
- Online Decompression
Image Processing
- Monitoring and Logging
- Parallel File System
Permissions Configuration Guide
- Differences Between OBS Permissions Control Methods
- OBS Access Control at a Glance
- Permission Control Methods
- Access Requests
Permission Configuration in Typical Scenarios
- Typical Permissions Scenarios
Granting Permissions to an IAM User Under the Current Account
- Granting an IAM User the Permissions to Create and List Buckets
- Granting an IAM User the Read/Write Permission on a Bucket
- Granting an IAM User the Specified Permissions for a Bucket
- Granting an IAM User the Read Permissions on Specific Objects
- Granting an IAM User the Specified Permissions on Specified Objects
Granting Permissions to Multiple IAM Users or User Groups Under the Current Account
- Granting IAM User Groups All Permissions for All OBS Resources
- Granting IAM User Groups Basic Permissions for All OBS Resources
- Granting IAM User Groups the Specified Permissions for All OBS Resources
- Granting IAM User Groups the Specified Permissions for Certain OBS Resources
- Granting IAM User Groups the Specified Permissions for a Folder
Granting Permissions to Other Accounts
- Granting Other Accounts the Read/Write Permission for a Bucket
- Granting Other Accounts the Specified Permissions for a Bucket
- Granting IAM Users Under an Account the Access to a Bucket and the Resources in It
- Granting Other Accounts the Read Permission for Certain Objects
- Granting Other Accounts the Specified Permissions for Certain Objects
- Granting Permissions to All Accounts
- Granting Temporary Access to OBS
- Allowing IAM Users to View Only Authorized Buckets
- Restricting Access to a Bucket for Specific IP Addresses
- Best Practices for Enterprise Data Access Control
- FAQs
- Appendix
Tools Guide
- OBS Tools
OBS Browser+
- Introduction
- OBS Browser+ Function Overview
- Downloading OBS Browser+
- Installing OBS Browser+
- Logging In to OBS Browser+
- Basic Bucket Operations
- Advanced Bucket Settings
- Object Operations
- Task Management
- Best Practices
- Where Can I Obtain Access Keys (AK and SK)?
- Where Can I Obtain an IAM User ID?
- Can I Install Two OBS Browser+ Tools from Different Sites in One System?
- What Are the Differences Between OBS Browser+ and OBS Browser?
- Does OBS Browser+ Support the Migration of Account and Task Information from OBS Browser?
- Why Does the Task Processing Speed Slow After the Number of Tasks Exceeds a Million?
- Why Are the Displayed Number of Objects and Used Storage Capacity Different from the Actual Number of Objects and Storage Capacity?
- Why Is the Deliver Attribute Configured Using an SDK Overwritten to False After I Configure a Bucket ACL on OBS Browser+?
- What If "Login request denied." Is Displayed When I Try to Log In to OBS Browser+ Using an Account?
- What If "Failed to obtain the user token from IAM." Is Displayed When I Try to Log In to OBS Browser+ Using an Account?
- What If Message "Incorrect Account or Password" Is Displayed When I Try to Log In to OBS Browser+ Using an Account?
- Will Incremental Upload Be Used in Auto Upload Tasks?
- How Can I Permanently Share Files or Folders with Other Users?
- How Can I Access a Specific Bucket or Directory?
- Can I Cancel the Directory Sharing After a Directory Has Been Shared with Others?
- Can I Query the Number and Size of Files in a Folder?
- How Do I Troubleshoot a DNS Resolution Failure?
- Can OBS Browser+ List Objects with Special Characters in Their Names?
- Why Are Objects Always in the Restoring State?
- Uninstalling OBS Browser+
- Change History
obsutil
- obsutil Introduction
- Downloading and Installing obsutil
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Uploading an Object
- Querying Object Properties
- Setting Object Properties
- Listing Objects
- Copying an Object
- Moving an Object
- Downloading an Object
- Generating the Download Link of an Object
- Deleting an Object
- Synchronously Uploading Incremental Objects
- Synchronously Copying Incremental Objects
- Synchronously Downloading Incremental Objects
- Restoring Objects from the Archive Storage
- Resuming a Failed Upload Task
- Resuming a Failed Copy Task
- Resuming a Failed Download Task
- Listing Multipart Upload Tasks
- Deleting a Multipart Upload Task
- Creating an Authorization Code for Directory Sharing
- Listing Objects by Using an Authorization Code
- Downloading Objects by Using an Authorization Code
- Auxiliary Commands
- Common Examples
- Fault Locating
Best Practices
- Using the obsutil help Command to Search for Functions
- Configuring Scheduled Tasks Using the Crontab Command
- Setting obsutil Commands as Built-in Commands
- Configuring Auto Obtaining of Access Keys for obsutil
- Fine-Tuning obsutil Performance
- Using obsutil for Resumable Data Transfer
- Using obsutil to Upload a Symbolic Link
- Configuring an HTTP Proxy for obsutil
- Using obsutil to Share Directories
- Using obsutil to Replicate Data Across Regions on the Client Side
- Limiting the Upload and Download Rate for obsutil
- After Some Files Are Deleted in My Local Directory, Can obsutil Synchronously Delete Them from the Bucket?
- Can I Use obsutil to Directly Save a Listing Result to a Local File?
- Why Is the Size of Objects Queried by obsutil Inconsistent with That on OBS Console?
- How Can I Find Out Why Some Tasks in a Batch Task Failed?
- How Can I Locate and Rectify I/O Timeout and EOF Errors?
- Why Is a Question Mark Displayed in the Batch Task Progress Bar?
- Can Multiple config Files Be Placed in One Directory?
- Why Is the Number of Objects I Downloaded from OBS to My Local Windows PC Different from That in OBS?
- Can I Rename an Object or a Folder?
- Configuration Parameters
- obsfs (abandoned)
Best Practices
- Overview
- Uploading Data to OBS
- Migrating Data to OBS
- Accessing Data Stored in OBS
- Using a User-Defined Domain Name to Host a Static Website
- Verifying Data Consistency
- Suggestions on OBS Security Configuration
- Suggestions on OBS Performance Optimization
- Using OBS to Decouple Storage from Compute in Big Data Scenarios
- Using s3fs to Mount an OBS Bucket
API Reference
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Operations on Buckets
- Configuring a Bucket Policy
- Obtaining Bucket Policy Information
- Deleting a Bucket Policy
- Configuring a Bucket ACL
- Obtaining Bucket ACL Information
- Configuring Logging for a Bucket
- Obtaining a Bucket Logging Configuration
- Configuring Bucket Lifecycle Rules
- Obtaining Bucket Lifecycle Configuration
- Deleting Lifecycle Rules
- Configuring Versioning for a Bucket
- Obtaining Bucket Versioning Status
- Configuring Storage Class for a Bucket
- Obtaining Bucket Storage Class Information
- Configuring Cross-Region Replication for a Bucket
- Obtaining the Cross-Region Replication Configuration of a Bucket
- Deleting the Cross-Region Replication Configuration of a Bucket
- Configuring Tags for a Bucket
- Obtaining Bucket Tags
- Deleting Tags
- Configuring Bucket Storage Quota
- Querying Bucket Storage Quota
- Obtaining Storage Information of a Bucket
- Configuring Bucket Inventories
- Obtaining a Specific Inventory of a Bucket
- Listing All Inventories of a Bucket
- Deleting Bucket Inventories
- Configuring a Custom Domain Name for a Bucket
- Obtaining the Custom Domain Name of a Bucket
- Deleting the Custom Domain Name of a Bucket
- Configuring Bucket Encryption
- Obtaining Bucket Encryption Configuration
- Deleting the Encryption Configuration of a Bucket
- Setting the Direct Reading Policy for Archive Objects in a Bucket
- Obtaining the Direct Reading Policy of Archive Objects in a Bucket
- Deleting the Direct Reading Policy of Archive Objects in a Bucket
- Configuring Mirroring Back-to-Source Rules
- Obtaining Mirroring Back-to-Source Rules
- Deleting Mirroring Back-to-Source Rules
- Setting an Online Decompression Policy
- Obtaining an Online Decompression Policy
- Deleting an Online Decompression Policy
- Configuring a Default WORM Policy for a Bucket
- Obtaining the Default WORM Policy of a Bucket
Static Website Hosting
- Configuring Static Website Hosting for a Bucket
- Obtaining the Static Website Hosting Configuration of a Bucket
- Deleting the Static Website Hosting Configuration of a Bucket
- Configuring Bucket CORS
- Obtaining the CORS Configuration of a Bucket
- Deleting the CORS Configuration of a Bucket
- OPTIONS Bucket
- OPTIONS Object
Operations on Objects
- Uploading an Object - PUT
- Uploading an Object - POST
- Copying an Object
- Querying Object Metadata
- Deleting Objects
- Restoring Archive or Deep Archive Objects
- Appending an Object
- Configuring an Object ACL
- Obtaining Object ACL Configuration
- Modifying Object Metadata
- Modifying an Object
- Truncating an Object
- Renaming an Object
- Configuring WORM Retention for an Object
- Operations on Multipart Upload
- Server-Side Encryption
- Error Codes
- Appendixes
SDK Reference
- SDK Overview
- SDK Function Matrices
Python
- Before You Start (SDK for Python)
- API Overview of OBS SDK for Python
- Preparations (SDK for Python)
- Downloading and Installing OBS SDK for Python
- Getting Started with OBS SDK for Python
- Initialization (SDK for Python)
Bucket-Related APIs (SDK for Python)
- Creating a Bucket (SDK for Python)
- Obtaining a Bucket List (SDK for Python)
- Checking Whether a Bucket Exists (SDK for Python)
- Deleting a Bucket (SDK for Python)
- Listing Objects in a Bucket (SDK for Python)
- Listing Object Versions in a Bucket (SDK for Python)
- Obtaining Bucket Metadata (SDK for Python)
- Obtaining the Region of a Bucket (SDK for Python)
- Obtaining Storage Information of a Bucket (SDK for Python)
- Configuring a Storage Quota (SDK for Python)
- Obtaining a Bucket Storage Quota (SDK for Python)
- Configuring a Storage Class for a Bucket (SDK for Python)
- Obtaining the Storage Class of a Bucket (SDK for Python)
- Configuring a Bucket ACL (SDK for Python)
- Obtaining a Bucket ACL (SDK for Python)
- Configuring Logging for a Bucket (SDK for Python)
- Obtaining the Logging Configuration of a Bucket (SDK for Python)
- Configuring a Bucket Policy (SDK for Python)
- Obtaining the Policy of a Bucket (SDK for Python)
- Deleting a Bucket Policy (SDK for Python)
- Configuring Lifecycle Rules for a Bucket (SDK for Python)
- Obtaining the Lifecycle Configuration of a Bucket (SDK for Python)
- Deleting the Lifecycle Configuration of a Bucket (SDK for Python)
- Configuring Static Website Hosting for a Bucket (SDK for Python)
- Obtaining Static Website Hosting for a Bucket (SDK for Python)
- Deleting Static Website Hosting for a Bucket (SDK for Python)
- Configuring Versioning for a Bucket (SDK for Python)
- Obtaining the Versioning Status of a Bucket (SDK for Python)
- Configuring CORS for a Bucket (SDK for Python)
- Obtaining the CORS Configuration of a Bucket (SDK for Python)
- Deleting the CORS Configuration of a Bucket (SDK for Python)
- Configuring Tags for a Bucket (SDK for Python)
- Obtaining Bucket Tags (SDK for Python)
- Deleting Bucket Tags (SDK for Python)
Object-Related APIs (SDK for Python)
- Object Upload Overview (SDK for Python)
- Uploading Objects - Text-Based (SDK for Python)
- Uploading an Object - Streaming (SDK for Python)
- Uploading an Object - File-Based (SDK for Python)
- Uploading an Object - Append (SDK for Python)
- Uploading an Object - Resumable (SDK for Python)
- Obtaining the Upload Progress (SDK for Python)
- Uploading an Object - Browser-Based (SDK for Python)
- Object Download Overview (SDK for Python)
- Downloading an Object - Binary (SDK for Python)
- Downloading an Object - Streaming (SDK for Python)
- Downloading an Object - File-Based (SDK for Python)
- Downloading an Object - Range-Based (SDK for Python)
- Downloading an Object - Resumable (SDK for Python)
- Downloading an Object - Obtaining the Download Progress (SDK for Python)
- Uploading an Object - Creating a Folder (SDK for Python)
- Copying an Object (SDK for Python)
- Deleting an Object (SDK for Python)
- Batch Deleting Objects (SDK for Python)
- Obtaining Object Metadata (SDK for Python)
- Modifying Object Metadata (SDK for Python)
- Configuring an Object ACL (SDK for Python)
- Obtaining an Object ACL (SDK for Python)
- Restoring an Archive Object (SDK for Python)
APIs Related to Multipart Upload (SDK for Python)
- Multipart Upload Overview (SDK for Python)
- Initiating a Multipart Upload (SDK for Python)
- Uploading a Part (SDK for Python)
- Listing Uploaded Parts (SDK for Python)
- Listing Multipart Uploads (SDK for Python)
- Assembling Parts (SDK for Python)
- Copying a Part (SDK for Python)
- Aborting a Multipart Upload (SDK for Python)
- Client-Side Encryption APIs (SDK for Python)
- Other APIs (SDK for Python)
- Troubleshooting (SDK for Python)
FAQs (SDK for Python)
- How Do I Make an Object Accessible to Anonymous Users? (SDK for Python)
- How Can I Obtain the AK and SK? (SDK for Python)
- How Do I Obtain an Object URL? (Python SDK)
- How Do I Improve the Uploading Speed of Large Files over the Public Network? (SDK for Python)
- How Do I Specify Content-SHA256? (SDK for Python)
- Why Does the SDK Source Code Contain acs.amazonaws.com? (SDK for Python)
- Setting an Object Expiration Time (SDK for Python)
- What Is Content-Type (MIME)? (Python SDK)
- How Do I Get My Account ID and IAM User ID? (SDK for Python)
Java
- Before You Start (SDK for Java)
- API Overview (SDK for Java)
- Preparations (SDK for Java)
- SDK Download and Installation (SDK for Java)
- Getting Started (SDK for Java)
- Initialization (SDK for Java)
Bucket Management (SDK for Java)
- Creating a Bucket (SDK for Java)
- Obtaining a Bucket List (SDK for Java)
- Deleting a Bucket (SDK for Java)
- Checking Whether a Bucket Exists (SDK for Java)
- Obtaining Bucket Metadata (SDK for Java)
- Configuring a Bucket ACL (SDK for Java)
- Obtaining a Bucket ACL (SDK for Java)
- Configuring a Bucket Policy (SDK for Java)
- Obtaining the Policy of a Bucket (SDK for Java)
- Deleting a Bucket Policy (SDK for Java)
- Obtaining the Region of a Bucket (SDK for Java)
- Obtaining Storage Information of a Bucket (SDK for Java)
- Configuring a Storage Quota (SDK for Java)
- Obtaining a Bucket Storage Quota (SDK for Java)
- Configuring a Storage Class for a Bucket (SDK for Java)
- Obtaining the Storage Class of a Bucket (SDK for Java)
- Bucket Inventory (SDK for Java)
- Parallel File System Management (SDK for Java)
Object Upload (SDK for Java)
- Overview (SDK for Java)
- Uploading an Object - Streaming (SDK for Java)
- Uploading an Object - File-Based (SDK for Java)
- Obtaining the Upload Progress (SDK for Java)
- Creating a Folder (SDK for Java)
- Configuring Object Metadata (SDK for Java)
Multipart Upload (SDK for Java)
- Multipart Upload Overview (SDK for Java)
- Initiating a Multipart Upload (SDK for Java)
- Uploading a Part (SDK for Java)
- Assembling Parts (SDK for Java)
- Code Example of a Multipart Upload (SDK for Java)
- Aborting a Multipart Upload (SDK for Java)
- Listing Uploaded Parts (SDK for Java)
- Listing Multipart Uploads (SDK for Java)
- Configuring Lifecycle Rules (SDK for Java)
- Uploading an Object - Append (SDK for Java)
- Uploading an Object - Resumable (SDK for Java)
- Uploading an Object - Browser-Based (SDK for Java)
Object Download (SDK for Java)
- Downloading an Object - Streaming (SDK for Java)
- Downloading an Object - Range-Based (SDK for Java)
- Obtaining the Download Progress (SDK for Java)
- Downloading an Object - Conditional (SDK for Java)
- Rewriting Response Headers (SDK for Java)
- Obtaining User-defined Metadata (SDK for Java)
- Restoring an Archive Object (SDK for Java)
- Downloading an Object - Resumable (SDK for Java)
- Downloading a Processed Image (SDK for Java)
- Creating a Signed URL for Downloading a Processed Image (SDK for Java)
Object Management (SDK for Java)
- Obtaining Object Metadata (SDK for Java)
- Configuring an Object ACL (SDK for Java)
- Obtaining an Object ACL (SDK for Java)
- Listing Objects (SDK for Java)
- Deleting an Object (SDK for Java)
- Batch Deleting Objects (SDK for Java)
- Copying an Object (SDK for Java)
- Copying an Object - Multipart (SDK for Java)
- Checking Whether an Object Exists (SDK for Java)
- Temporarily Authorized Access (SDK for Java)
Versioning (SDK for Java)
- Configuring Versioning for a Bucket (SDK for Java)
- Obtaining the Versioning Status of a Bucket (SDK for Java)
- Obtaining an Object Version (SDK for Java)
- Copying an Object Version (SDK for Java)
- Restoring a Specific Archive Object Version (SDK for Java)
- Listing Object Versions (SDK for Java)
- Setting an ACL for an Object Version (SDK for Java)
- Obtaining the ACL of an Object Version (SDK for Java)
- Deleting an Object Version (SDK for Java)
- Batch Deleting Object Versions (SDK for Java)
- Lifecycle Management (SDK for Java)
- Cross-Origin Resource Sharing (SDK for Java)
- Logging (SDK for Java)
- Static Website Hosting (SDK for Java)
- Bucket Tag Management (SDK for Java)
- Server-Side Encryption (SDK for Java)
- Client-Side Encryption (SDK for Java)
- Fault Locating (SDK for Java)
- Troubleshooting (SDK for Java)
FAQs (SDK for Java)
- Can I Use This Document for Union SDK?
- How Can I Set an Object to Be Accessible to Anonymous Users? (Java SDK)
- What Is the Retry Mechanism of SDK? (SDK for Java)
- How Do I Obtain the Static Website Access Address of a Bucket? (Java SDK)
- How Do I Obtain an Object URL? (Java SDK)
- How to Improve the Speed of Uploading Large Files over the Public Network? (SDK for Java)
- How Can I Perform a Multipart Upload? (SDK for Java)
- How Can I Perform a Download in Multipart Mode? (Java SDK)
- How Do I Confirm that an Upload is Successful If I Upload an Object to Overwrite an Existing Object with the Same Name in a Bucket? (SDK for Java)
- How Do I Download an Encrypted Object Using a URL? (SDK for Java)
- How Do I Generate an SSE-C Encryption Key?
- How Do I Obtain the Security Token? (Java SDK)
- Does the SDK Support Uploading, Downloading, or Copying Objects in a Batch? (Java SDK)
- Why Does the SDK Source Code Contain acs.amazonaws.com? (Java SDK)
- What Is Content-Type (MIME)? (Java SDK)
- How Do I Get My Account ID and User ID?
Go
- Before You Start (SDK for Go)
- API Overview of OBS SDK for Go
- Preparations (SDK for Go)
- Downloading and Installing OBS SDK for Go
- Getting Started with OBS SDK for Go
- Initializing OBS SDK for Go
Buckets (SDK for Go)
- Bucket API Overview (SDK for Go)
- Creating a Bucket (SDK for Go)
- Obtaining a Bucket List (SDK for Go)
- Checking Whether a Bucket Exists (SDK for Go)
- Deleting a Bucket (SDK for Go)
- Listing Objects in a Bucket (SDK for Go)
- Listing Object Versions in a Bucket (SDK for Go)
- Obtaining Bucket Metadata (SDK for Go)
- Obtaining the Region of a Bucket (SDK for Go)
- Obtaining Storage Information of a Bucket (SDK for Go)
- Configuring a Storage Quota (SDK for Go)
- Obtaining a Bucket Storage Quota (SDK for Go)
- Configuring Storage Class for a Bucket (SDK for Go)
- Obtaining the Storage Class of a Bucket (SDK for Go)
- Configuring a Bucket ACL (SDK for Go)
- Obtaining the Bucket ACL (SDK for Go)
- Configuring Logging for a Bucket (SDK for Go)
- Obtaining the Logging Configuration of a Bucket (SDK for Go)
- Configuring a Bucket Policy (SDK for Go)
- Obtaining the Policy of a Bucket (SDK for Go)
- Deleting a Bucket Policy (SDK for Go)
- Configuring Lifecycle Rules for a Bucket (SDK for Go)
- Obtaining the Lifecycle Configuration of a Bucket (SDK for Go)
- Deleting the Lifecycle Configuration of a Bucket (SDK for Go)
- Configuring Static Website Hosting for a Bucket (SDK for Go)
- Obtaining the Static Website Hosting Configuration of a Bucket (SDK for Go)
- Deleting the Static Website Hosting Configuration of a Bucket (SDK for Go)
- Configuring Versioning for a Bucket (SDK for Go)
- Obtaining the Versioning Status of a Bucket (SDK for Go)
- Configuring CORS for a Bucket (SDK for Go)
- Obtaining the CORS Configuration of a Bucket (SDK for Go)
- Deleting the CORS Configuration of a Bucket (SDK for Go)
- Configuring Tags for a Bucket (SDK for Go)
- Obtaining Bucket Tags (SDK for Go)
- Deleting Bucket Tags (SDK for Go)
- Configuring Bucket Encryption (SDK for Go)
- Obtaining the Bucket Encryption Configuration (SDK for Go)
- Deleting the Bucket Encryption Configuration (SDK for Go)
- Configuring a Custom Domain Name for a Bucket (SDK for Go)
- Obtaining the Custom Domain Name of a Bucket (SDK for Go)
- Deleting the Custom Domain Name of a Bucket (SDK for Go)
- Parallel File System APIs (SDK for Go)
Objects (SDK for Go)
- Object API Overview (SDK for Go)
- Object Upload Overview (SDK for Go)
- Object Download Overview (SDK for Go)
- Creating a Folder (SDK for Go)
- Copying an Object (SDK for Go)
- Deleting an Object (SDK for Go)
- Batch Deleting Objects (SDK for Go)
- Configuring Object Metadata (SDK for Go)
- Obtaining Object Metadata (SDK for Go)
- Configuring an Object ACL (SDK for Go)
- Obtaining Object ACL Information (SDK for Go)
- Rewriting Response Headers (SDK for Go)
- Processing an Image (SDK for Go)
- Restoring an Archive Object (SDK for Go)
- Modifying an Object (SDK for Go)
- Multipart Uploads (SDK for Go)
- Other APIs (SDK for Go)
- Single-Connection Bandwidth Throttling (SDK for Go)
- Troubleshooting (SDK for Go)
- FAQ (SDK for Go)
Android
- Installing the SDK
- Example Programs
- Quick Start
- Initialization
- Bucket Management
Object Upload
- Performing a Streaming Upload
- Performing a File-Based Upload
- Obtaining Upload Progresses
- Creating a Folder
- Performing a Multipart Upload
- Configuring Lifecycle Management
- Performing an Appendable Upload
- Performing a Multipart Copy
- Performing a Resumable Upload
- Performing a Browser-Based Upload
- Object Download
- Object Management
- Versioning Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQ
- API Reference
C
- Before You Start
- Downloading and Installing the SDK
- Quick Start
- Initialization
- Bucket Management
- Object Management
- Temporarily Authorized Request
- Accessing OBS Through a User-Defined Domain Name
- Cross-Origin Resource Sharing (CORS)
- Setting Access Logging
- Tag Management
- Troubleshooting
- FAQs
BrowserJS
- Before You Start
- SDK Download Links
- Example Programs
- Quick Start
- Initialization
- Fault Locating
- Bucket Management
Object Upload
- Performing a Text-Based Upload
- Creating a Folder
Object Download
- Performing a Text-Based Download
- Performing a Binary Download
- Performing a File-Based Download
- Performing a Partial Download
- Obtaining Download Progresses
- Performing a Conditioned Download
- Obtaining Customized Metadata
- Downloading an Archive Object
- Object Management
- Access Logging
- Tag Management
- Troubleshooting
- How Do I Upload Files Using a Browser that Does Not Support window.File?
- How Do I Suspend a Resumable Upload Task?
- How Do I Interact with OBS Without Exposing My AK and SK?
- How Do I Upload a Base64-Encoded Image?
- What Do I Do If the Resumable Upload API Reports a "400 InvalidPart" Error?
iOS
- Compatibility
- Quick Start
- Initialization
- Bucket Management
Object Upload
- Creating a Folder
- Appendable Upload
- Pausing and Resuming/Aborting a Resumable Upload
- Object Download
- Object Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQ
- API Reference
PHP
- Example Programs
Quick Start
- Before You Start
- Setting Up an OBS Environment
- Preparing a Development Environment
- Obtaining Endpoints
- Initializing an Instance of ObsClient
- Creating a Bucket
- Listing Objects
- General Examples of ObsClient
- Pre-defined Constants
- Initialization
- Bucket Management
- Object Upload
- Object Download
- Object Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQs
Node.js
- Downloading an SDK (SDK for Node.js)
- Example Programs (SDK for Node.js)
Getting Started (SDK for Node.js)
- Before You Start (SDK for Node.js)
- Setting Up an OBS Environment (SDK for Node.js)
- Preparing a Development Environment (SDK for Node.js)
- Installing the SDK (SDK for Node.js)
- Obtaining Endpoints (SDK for Node.js)
- Initializing an Instance of ObsClient (SDK for Node.js)
- Creating a Bucket (SDK for Node.js)
- Uploading an Object (SDK for Node.js)
- Downloading an Object (SDK for Node.js)
- Listing Objects (SDK for Node.js)
- Deleting an Object (SDK for Node.js)
- General Ways to Use ObsClient (SDK for Node.js)
- Initialization (SDK for Node.js)
Bucket Management (SDK for Node.js)
- Listing Buckets (SDK for Node.js)
- Checking Whether a Bucket Exists (SDK for Node.js)
- Deleting a Bucket (SDK for Node.js)
- Obtaining Bucket Metadata (SDK for Node.js)
- Configuring a Bucket ACL (SDK for Node.js)
- Obtaining a Bucket ACL (SDK for Node.js)
- Configuring a Bucket Policy (SDK for Node.js)
- Obtaining the Policy of a Bucket (SDK for Node.js)
- Deleting a Bucket Policy (SDK for Node.js)
- Obtaining the Region of a Bucket (SDK for Node.js)
- Obtaining Storage Information of a Bucket (SDK for Node.js)
- Configuring a Storage Quota for a Bucket (SDK for Node.js)
- Obtaining the Storage Quota of a Bucket (SDK for Node.js)
- Configuring a Storage Class for a Bucket (SDK for Node.js)
- Obtaining the Storage Class of a Bucket (SDK for Node.js)
Object Upload (SDK for Node.js)
- Object Upload Overview (SDK for Node.js)
- Uploading an Object - Text-Based (SDK for Node.js)
- Uploading an Object - Streaming (SDK for Node.js)
- Uploading an Object - File-Based (SDK for Node.js)
- Creating a Folder (SDK for Node.js)
- Configuring Object Metadata (SDK for Node.js)
- Configuring a Lifecycle Rule When Uploading an Object (SDK for Node.js)
- Uploading an Object - Append (SDK for Node.js)
- Uploading an Object - Resumable (SDK for Node.js)
- Uploading an Object - Browser-Based (SDK for Node.js)
Object Download (SDK for Node.js)
- Overview (SDK for Node.js)
- Downloading an Object - Text-Based (SDK for Node.js)
- Downloading an Object - Streaming (SDK for Node.js)
- Downloading an Object - File-Based (SDK for Node.js)
- Downloading an Object - Range-Based (SDK for Node.js)
- Downloading an Object - Conditional (SDK for Node.js)
- Rewriting Response Headers (SDK for Node.js)
- Downloading an Archive Object (SDK for Node.js)
- Downloading an Object - Resumable (SDK for Node.js)
- Processing an Image (SDK for Node.js)
Object Management (SDK for Node.js)
- Obtaining Object Metadata (SDK for Node.js)
- Configuring an Object ACL (SDK for Node.js)
- Obtaining the ACL of an Object (SDK for Node.js)
- Listing Objects in a Bucket (SDK for Node.js)
- Batch Deleting Objects (SDK for Node.js)
- Copying an Object (SDK for Node.js)
Multipart Upload (SDK for Node.js)
- Multipart Upload APIs (SDK for Node.js)
- Initiating a Multipart Upload (SDK for Node.js)
- Uploading a Part (SDK for Node.js)
- Assembling Parts (SDK for Node.js)
- Listing Uploaded Parts (SDK for Node.js)
- Listing Multipart Uploads (SDK for Node.js)
- Copying a Part (SDK for Node.js)
- Aborting a Multipart Upload (SDK for Node.js)
- Temporarily Authorized Access (SDK for Node.js)
Versioning (SDK for Node.js)
- Versioning Overview (SDK for Node.js)
- Configuring Versioning for a Bucket (SDK for Node.js)
- Viewing the Versioning Status of a Bucket (SDK for Node.js)
- Obtaining an Object Version (SDK for Node.js)
- Copying an Object Version (SDK for Node.js)
- Restoring an Archive Object Version (SDK for Node.js)
- Listing Object Versions in a Bucket (SDK for Node.js)
- Setting an ACL for an Object Version (SDK for Node.js)
- Obtaining the ACL of an Object Version (SDK for Node.js)
- Deleting an Object Version (SDK for Node.js)
- Lifecycle (SDK for Node.js)
- Bucket CORS (SDK for Node.js)
- Logging (SDK for Node.js)
- Static Website Hosting (SDK for Node.js)
- Tagging (SDK for Node.js)
- Server-Side Encryption (SDK for Node.js)
- Troubleshooting (SDK for Node.js)
- FAQs (SDK for Node.js)
.NET
- Before You Start
- Example Programs
- Quick Start
- Initialization
Bucket Management
- Creating a Bucket
- Listing Buckets
- Deleting a Bucket
- Identifying Whether a Bucket Exists
- Managing Bucket ACLs
- Management Bucket Policies
- Obtaining a Bucket Location
- Obtaining Storage Information About a Bucket
- Setting or Obtaining a Bucket Quota
- Setting or Obtaining the Storage Class of a Bucket
Object Upload
- Performing an Asynchronous Upload
- Creating a Folder
Object Download
- Performing a Streaming Download
- Performing an Asynchronous Download
- Obtaining Custom Metadata
- Performing a Resumable Download
- Object Management
- CORS
- Access Logging
- Tag Management
- Troubleshooting
- FAQ
OBS Basics
- How Do I Obtain an OBS Endpoint?
- How Much Data Can I Store in OBS?
- How Can I Determine Which Region to Store My Data In?
- Does OBS Support Access over HTTPS?
- Can Other Users Access My Data Stored in OBS?
- Why Is an Alarm Reported When I Access OBS and What Can I Do?
- Can Deleted Data Be Recovered?
- What Can I Do If My Access to the OBS Domain Name Failed Due to a CA Certificate Connection Failure?
- Why Did Some of My Data Stored on OBS Get Lost?
- Does OBS Support Traffic Monitoring?
- What Are the Factors That Affect Upload and Download Speeds of OBS?
- What Are the Advantages of Object Storage over SAN and NAS Storage?
- Can Folders in OBS Be Used the Same Way as in a File System?
- What Are the Differences Between OBS, EVS, and SFS?
- How Do I Determine Whether I Am Accessing OBS over an Intranet?
- Will My Bucket Performance Be Affected by Other Users' Services?
- Why Is My Data on the OBS Bucket Overview Page Inconsistent?
- What Can I Do If There Are Packet Loss and Network Instability Problems In Cross-Border Data Transfer Scenarios?
Billing
- Why Does My Bucket Generate Storage Costs Even Though There Are No Objects in It?
- Why Does My Bucket Generate Traffic When There Are No Objects in It?
- Why Am I Still Being Billed After I Purchased a Resource Package?
- Why Am I Still Being Billed for Pull Traffic Used by CDN Acceleration When I Already Have a Pull Traffic Package?
- Why Are OBS Resources Still Unavailable Even Though My Account Has a Valid Payment Method and There Are No Outstanding Bills?
- Do I Have to Purchase a Resource Package? Can I Apply a Package to a Specific Bucket?
- Can I Unsubscribe from or Modify a Resource Package?
- What Can I Do If My Resource Package Expires?
- Do Parallel File Systems Support Resource Packages?
- How Are Requests Counted?
- Can I Purchase Requests?
- Will My Data Write Be Restricted When My OBS Package Has Been Used Up?
- Will the Remaining Package Quota in a Given Month Be Carried over to the Following Month?
- Which Types of Resource Packages Will Reset Their Quota by Month and Which Types Will Not?
- Do I Need to Purchase an Outbound Internet Traffic Package If I Already Have a Pull Traffic Package?
- Why Is There a Charge of $0.01 USD on My OBS Bill?
- Why Is There a Large Amount of Outbound Internet Traffic in My Bill?
Access Control
- Why Is the Message "Access denied" Still Appearing After OBS System Permissions or Bucket Read and Write Permissions Are Allowed?
- Why Can't I Access OBS (403 AccessDenied) After Being Granted with the OBS Access Permission?
- What Is the Relationship Between a Bucket Policy and an Object Policy?
- How Do I Control Access to Folders in an OBS Bucket?
- Why Was the Value of the delivered Parameter Changed to false After I Configured the Bucket ACL for Anonymous Users on the OBS Console?
Buckets and Objects
- Why Am I Unable to Create a Bucket?
- Why Am I Unable to Upload an Object?
- Why Am I Unable to Download an Object?
- Why Can't I Delete a Bucket?
- Why Can't I Delete an Object?
- Why Can't I Access an Object Through Its URL?
- How Do I Preview OBS Objects in My Web Browser?
- Can I Rename an Object?
- Can I Edit Objects in OBS Online?
- How Do I Obtain the Access Path to an Object?
- Can I Modify the Region of a Bucket?
- How Do I Change the Enterprise Project Where My Bucket Belongs?
- Can I Copy a File Between Buckets?
- Can I Move a File Between Buckets?
- Can I Upload Objects with the Same Name to the Same Folder?
- Does OBS Support Resumable Transfer?
- Does OBS Support Batch Upload?
- Does OBS Support Batch Download?
- Does OBS Support Batch Deletion of Objectsor Emptying a Bucket?
- What If an Object Can't Be Found in a Bucket or a 403 Error Is Returned?
- What Should I Do If an Error Message Is Displayed When I Use Internet Explorer to Access an Object URL That Contains Chinese Characters?
- Why Is an Error Reported Even If OBS CORS Has Been Configured?
- How Do I Query the Size of a Folder in a Bucket?
- How Do I Upload Objects Larger Than 5 GB?
Data Security, Migration, and Backup
- How Is Data Security Ensured in OBS?
- Can I Recover OBS Data After It Is Deleted or Overwritten?
- Can I Change the AK and SK or Share Them with Others for Accessing OBS?
- How Do I Migrate Data to OBS?
- How Does OBS Implement Backup and Disaster Recovery?
- How Can I Migrate Data Between SFS and OBS?
- Does OBS Scan My Data for Other Purposes?
- Can Engineers Export My Data from the Background of OBS?
- How Does OBS Protect My Data from Being Stolen?
- How Durable and Available Is OBS?
- What Are the Differences Between Single-AZ and Multi-AZ Storage in OBS?
- What Redundancy Techniques Does OBS Use?
- Versioning
- How Do I Access or Download an Encrypted Object?
- Why Cannot an Authorized Account or User Upload or Download KMS Encrypted Objects?
- Are Additional Permissions Required When I Share an Object with SSE-OBS Encrypted?
- Does OBS Support Encrypted Upload?
- What Techniques Can I Use to Encrypt Data on OBS?
- Will OBS Server-Side Encryption Encrypt My Existing Objects That Are Unencrypted?
- Will I Be Billed for the Encryption Provided by OBS Server-Side Encryption?
- Does OBS SSE-KMS Allow Anonymous Access?
- How Do I Use Cross-Region Replication?
- Why Is the Message "NoSuchBucket" Displayed When I Use a User-Defined Domain Name to Access a Bucket That Can Be Accessed by the OBS Domain Name?
- With CDN Acceleration Enabled, Why Are the Objects in My OBS Bucket Directly Downloaded When I Access Them?
- What Is the Relationship Between OBS Bucket Names and Domain Names?
- Why Is the CNAME Resolution Status Unknown?
- Why Can Only the Domain Names I Bought on Huawei Cloud Be Automatically Resolved In One Click?
- How Do I Use Static Website Hosting?
Image Processing
- How Do I Access Image Processing with a URL?
- After CDN Acceleration Is Enabled, Where Are Processed Images Stored?
- After I Performed Image Processing in My Logging-enabled Bucket, Why Was My Bucket Accessed by IP Addresses Starting with 100?
- How Is Image Processing Billed?
- How Many Image Styles Can I Create in a Bucket?
- Monitoring
OBS Console
- Web Browser Compatibility
- Time Difference Is Longer Than 15 Minutes Between the Client and Server
- The Object Name Changes After an Object with a Long Name Is Downloaded to a Local Computer
- An Object Fails to Be Downloaded Using Internet Explorer 11
- OBS Console Couldn't Be Opened in Internet Explorer 9
- Error Code List
OBS Browser+, obsutil, and Other OBS Tools
- When Downloading a Folder Using obsutil, the Download Speed Slows After the Folder Download Progress Reaches 90%
- With obsutil, Downloading a File Fails After the Download Progress Reaches 99%
- Slow Upload and Download Through obsutil
- How Do I Use the obsutil cp Command to Enable Incremental Upload, Download, or Replication?
- Can I Mount My Parallel File System to a Windows Server?
APIs and SDKs
- Failure with OBS SDK in Uploading a File Greater than 5 GB
- What Can I Do When Error Message "okhttp3.RequestBody.create(java.lang.String,okhttp3.MediaType)" Is Displayed for Java SDK?
- What Are the Differences Between PUT and POST Upload Methods?
- Does an Append Upload Support the Lock Mechanism for Concurrent Operations?
- Why Don't the Signatures Match?
OBS Basics
- Videos
- Glossary
More Documents
- Billing
OBS Console Operation Guide
- Console Function Overview
- Restrictions
- Getting Started
- Storage Classes Overview
- Managing Buckets
- Managing Objects
- Object Metadata
Permission Control
- Overview
- Permission Control Mechanisms
- Bucket Policy Parameters
- Configuring IAM Policies
- Configuring an Object Policy
Application Cases
- Granting an IAM User with the Operation Permissions for a Specified Bucket
- Granting Other Accounts with the Operation Permissions for a Specified Bucket
- Restricting Bucket Access to a Specified Address
- Configuring the Start Time and End Time of Access to Objects in a Bucket
- Authorizing Access Permissions to Anonymous Users
- Authorizing Folder Access Permissions to Anonymous Users
- Versioning
- Logging
- Tags
- Event Notification
- User-Defined Domain Name Binding
- CORS
- URL Validation
- Monitoring
- Related Operations
Troubleshooting
- OBS Console Cannot Be Opened in Internet Explorer 9
- Failed to Configure Event Notification
- Error Code List
OBS Basics
- How Can I Get Started Using OBS?
- Which Types of Data Can Be Stored in OBS?
- Where Is Data Stored in OBS?
- What Is the Relationship Between OBS Bucket Names and OBS Domain Names?
- Does OBS Support Resumable Data Transfer?
- Does OBS Support Batch Deletion of Objects?
- What Are Factors that Affect the Upload and Download Speed of OBS?
- Will There Be Data Left Over in OBS After I Delete an Object?
- Access Control
Buckets and Objects
- What Is the Relationship Between Bucket Storage Classes and Object Storage Classes?
- Why Can't I Find Certain Objects in a Bucket When I Searched for Them?
Security
- Can Background Engineers Export My Data from OBS?
- How Does OBS Prevent My Data from Being Stolen?
- Can a Pair of AK and SK Be Replaced When They Are Being Used to Access OBS?
- Can a Pair of AK and SK Be Used by Multiple Users to Access OBS?
- Which Encryption Technologies Are Supported by OBS?
- How Do I Use Fragment Management?
- How Do I Use Versioning?
- How Do I Use Tags?
- How Do I Use Lifecycle Management?
OBS Basics
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Configuring Event Notification for a Bucket
- Obtaining the Event Notification Configuration of a Bucket
- Deleting Tags
- Configuring a DIS-Enabled Notification Policy
- Obtaining a DIS-Enabled Notification Policy
- Deleting a DIS-Enabled Notification Policy
- OPTIONS Bucket
- OPTIONS Object
- Uploading Objects - PUT
- Uploading Objects - POST
- Copying Objects
- Deleting Objects
- Restoring Cold Objects
- Error Codes
- IAM Policies and Supported Actions
- Appendixes
- Change History
Tool Guide (OBS Browser+) (ME-Abu Dhabi Region)
- Introduction
- How Can I Locate Common Network Errors?
- Can I Query the Number and Size of Files in a Folder on OBS Browser+?
- Change History
- Tool Guide (obsfs) (ME-Abu Dhabi Region)
Tool Guide (obsutil) (ME-Abu Dhabi Region)
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Listing Objects
- Copying an Object
- Moving an Object
- Restoring Objects from the Storage
- Common Examples
- Fault Locating
Best Practices
- Change History
- Parallel File System Feature Guide(ME-Abu Dhabi Region)
User Guide (Paris Region)
- Restrictions
- Getting Started
- Managing Buckets
- Managing Objects
- Object Metadata
Permissions Control
- Overview
Application Cases
- Granting an IAM User Permissions to Operate a Specific Bucket
- Granting Other Accounts Permissions to Operate a Specific Bucket
- Restricting Access to a Bucket for Specific Addresses
- Limiting the Time When Objects in a Bucket Are Accessible
- Granting Anonymous Users Permission to Access Objects
- Granting Anonymous Users Permission to Access Folders
- Versioning
- Logging
- Event Notifications
- Cross-Region Replication
- Configuring User-Defined Domain Names
- URL Validation
- Monitoring
Troubleshooting
- Failed to Configure Event Notifications
- Error Code List
FAQ
OBS Basics
- How Can I Get Started with OBS?
- What Are the Factors That Affect Upload and Download Speed of OBS?
- Access Control
Buckets and Objects
- Why Can't I Search for Certain Objects in My Bucket?
- Tools
- APIs and SDKs
Security
- Can a Pair of AK and SK Be Replaced When It Is Being Used to Access OBS?
- Can Multiple Users Share One Pair of AK and SK to Access OBS?
OBS Basics
- Change History
Tool Guide (OBS Browser+) (Paris Region)
- Introduction
- Does OBS Browser+ Support the Migration of Account and Task Information From OBS Browser?
- Change History
- Tool Guide (obsfs) (Paris Region)
Tool Guide (obsutil) (Paris Region)
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Listing Objects
- Copying an Object
- Moving an Object
- Restoring Objects from the Cold Storage
- Common Examples
- Fault Locating
Best Practices
- Change History
- Parallel File System Feature Guide(Paris Region)
Image Processing (Paris Region)
- Introduction
- Start to Process (Using OBS Console)
- Start to Process (Using APIs)
- Typical Cases
- Obtaining Image Information
- Obtaining Average RGB Value of an Image
- Resizing Images
- Rotating Images
- Cropping Images
- Changing Quality
- Slimming Images
- Image Persistency
- FAQ
- Change History
Permissions Configuration Guide (Paris Region)
- Introduction to OBS Access Control
- Access Requests
- Typical Permission Control Scenarios
Configuration Cases in Typical Permission Control Scenarios
- Granting an IAM User the Permissions Required to List and Create Buckets
- Granting an IAM User the Read/Write Permission for a Bucket
- Granting an IAM User the Read Permission for Specific Objects
- Granting an IAM User the Specified Permissions for Certain Objects
- Granting Permissions to Anonymous Users
- Appendix
- Change History
- Restrictions
- Getting Started
- Managing Buckets
- Managing Objects
- Object Metadata
- Bucket Inventories
Permissions Control
- Overview
Application Cases
- Versioning
- Logging
- Tags
- URL Validation
- Monitoring
Troubleshooting
- Error Code List
FAQ
OBS Basics
- Access Control
Buckets and Objects
- What Do I Do If I Encounter an Error While Trying to Access an Object URL with Full-Width Characters Using Internet Explorer?
- Tools
- APIs and SDKs
Security
- Fragment Management
- Versioning
- Tags
OBS Basics
- Change History
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Deleting Tags
- OPTIONS Bucket
- OPTIONS Object
- Copying an Object
- Deleting Objects
- Error Codes
- Appendixes
- Change History
Tool Guide (OBS Browser+) (Kuala Lumpur Region)
- Introduction
- Change History
- Tool Guide (obsfs) (Kuala Lumpur Region)
- Parallel File System Feature Guide (Kuala Lumpur Region)
- Best Practices (Kuala Lumpur Region)
User Guide (Ankara Region)
- Configuration Before Use
- Restrictions
- Getting Started
- Managing Buckets
- Managing Objects
- Object Metadata
Permissions Control
- Overview
Application Cases
- Versioning
- Logging
- Cross-Cluster Replication
- URL Validation
- Task Center
- Two-AZ DR
Troubleshooting
- Error Code 500 Is Returned When a Bucket with the Name of the Bucket Failing to Be Created in AZ 2 Is Created in AZ 1
- Object Upload or Download Errors
- Error Code List
FAQ
OBS Basics
- Access Control
Buckets and Objects
- Does OBS Support Storage Quota Management?
Security
- Durability and Availability
- Versioning
OBS Basics
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- Getting Started
APIs
- Deleting Tags
- Configuring Cross-Cluster Replication for a Bucket
- Obtaining the Cross-Cluster Replication Configuration of a Bucket
- Deleting the Cross-Cluster Replication Configuration of a Bucket
- OPTIONS Bucket
- OPTIONS Object
- Copying an Object
- Deleting Objects
- Error Codes
- Appendixes
- Change History
- Parallel File System Feature Guide(Ankara Region)
Tool Guide (OBS Browser+) (Ankara Region)
- Introduction
- Change History
Tool Guide (obsutil) (Ankara Region)
- Getting Started
- Bucket Commands
Object Commands
- Creating a Folder
- Listing Objects
- Copying an Object
- Moving an Object
- Common Examples
- Fault Locating
Best Practices
- Change History
Operation Guide (Leaving soon. Moving to User Guide.)
- Before You Start
- Storage Classes
- Bucket Management
- Object Management
- Data Management
- Data Access
- Data Security
- Data Processing
Image Processing (Leaving soon. Moving to User Guide.)
- Introduction
- Typical Cases
- Resizing Images
- Rotating Images
- Cropping Images
- Converting Image Formats
- Slimming Images
FAQ
- What Is Image Processing?
- How Do I Access Image Processing?
- What Formats Does Image Processing Support?
- Where Are Processed Images Stored After CDN Acceleration Is Enabled?
- Why Was My Bucket Accessed by IP Addresses Starting with 100 After I Performed Image Processing in My Logging-enabled Bucket?
- Parallel File System (Leaving soon. Moving to User Guide.)
Show all
Configuring a Custom Bucket Policy
If you want to grant special permissions to specific users, you can configure custom bucket policies. If a standard bucket policy conflicts with a custom bucket policy, the authorization priority is given to the custom bucket policy and then the standard bucket policy.
- In the bucket list, click the bucket to be operated. The Overview page of the bucket is displayed.
- In the navigation pane on the left, click Permissions to go to the permission management page.
- On the Bucket Policies tab page, configure a custom bucket policy according to your needs.
- Click Create Bucket Policy. Select a proper policy mode as required. Valid values are as follows:
- Read-only: The authorized user will be granted with the read permission on the bucket and objects. For subsequent operations, see 5.
- Read and write: The authorized user will be granted with read and write permissions on the bucket and objects. For subsequent operations, see 5.
- Customized: The authorized user will be granted with customized permissions on the bucket and objects. For detailed configuration, see 6.
Only one bucket policy mode can be configured at a time.
- For the read-only and read and write modes, enter information about the authorized user in the following format and click OK.
Table 1 Parameters in bucket policies Parameter
Value
Principal
- Include or Exclude
- Current account or Other account
Specifies users on whom this bucket policy takes effect.
- Include: Specifies the user on whom the bucket policy statement takes effect.
- Exclude: Specifies that on all users except the specified user the bucket policy statement takes effect.
Resources
Indicates the resource that a bucket policy applies to. With the read-only mode and read and write mode, the policy can only apply to objects.
- Include: Specifies the OBS resources on which the bucket policy statement takes effect.
- Exclude: Specifies that on all OBS resources except the specified ones the bucket policy statement takes effect.
- For the customized mode, set parameters based on the site requirements and click OK.
Table 2 lists the meaning of each parameter.
Table 2 Parameters in bucket policies Parameter
Value
Effect
Allow or Deny
Effect of a bucket policy.
- Allow: Indicates access requests are allowed, if they match the configurations of this bucket policy.
- Deny: Indicates access requests are denied, if they match the configurations of this bucket policy.
Principal
Resources
Relationship between resource types and actions:
- When a resource is an object or an object set, only the actions related to the object can be configured.
- When the resource is a bucket, only the actions related to the bucket can be configured.
Actions
- For details, see Actions.
Operations stated in the bucket policy.
- Include: Specifies the actions on which the bucket policy takes effect.
- Exclude: Specifies that on all actions except the specified ones the bucket policy takes effect.
Conditions
Conditions for the policy statement to take effect.
