Security Configuration
Configuring Security Channel Encryption
The channels between components are not encrypted by default. You can set the following parameters to configure security channel encryption.
Page access: On FusionInsight Manager, choose Cluster > Name of the desired cluster > Services > component > Configurations. Click All Configurations. Enter the parameter name in the search box.
   Restart the corresponding service after configuration.
        Parameter  |
        Description  |
        Default Value  |
        hbase.rpc.protection  |
        Indicates whether the HBase channels, including the remote procedure call (RPC) channels for HBase clients to access the HBase server and the RPC channels between the HMaster and RegionServer, are encrypted. If this parameter is set to privacy, the channels are encrypted and the authentication, integrity, and privacy functions are enabled. If this parameter is set to integrity, the channels are not encrypted and only the authentication and integrity functions are enabled. If this parameter is set to authentication, the channels are not encrypted, only packets are authenticated, and integrity and privacy are not required.
         The privacy mode encrypts transmitted content, including sensitive information such as user tokens, to ensure the security of the transmitted content. However, this mode has great impact on performance. Compared with the other two modes, this mode reduces read/write performance by about 60%. Modify the configuration based on the enterprise security requirements. The configuration items on the client and server must be the same.  |
        dfs.encrypt.data.transfer  |
        Indicates whether the HDFS data transfer channels and the channels for clients to access HDFS are encrypted. The HDFS data transfer channels include the data transfer channels between DataNodes and the Data Transfer (DT) channels for clients to access DataNodes. The value true indicates that the channels are encrypted. The channels are not encrypted by default.  |
        false  |
        dfs.encrypt.data.transfer.algorithm  |
        Indicates whether the HDFS data transfer channels and the channels for clients to access HDFS are encrypted. This parameter is valid only when dfs.encrypt.data.transfer is set to true. The default value is 3des, which indicates that the 3DES algorithm is used for encryption. The value can also be set to rc4; however, to avoid security risks, do not set the parameter to this value.  |
        3des  |
        hadoop.rpc.protection  |
        Indicates whether the RPC channels of each module in Hadoop are encrypted. The channels include:
 The privacy indicates that the channels are encrypted by default. The authentication indicates that channels are not encrypted.
         You can set this parameter on the HDFS component configuration page. The parameter setting is valid globally, that is, the setting of whether the RPC channel is encrypted takes effect on all modules in Hadoop.  |
Setting the Maximum Number of Concurrent Web Connections
To ensure Web server security, the number of new connections is limited when the number of user connections reaches a specific threshold. This prevents DDOS attacks and service unavailability caused by too many users accessing the web server at the same time.
Page access:
        Parameter  |
        Description  |
        Default Value  |
        hadoop.http.server.MaxRequests  |
        Specifies the maximum number of concurrent web connections of each component. Components include HDFS and YARN.  |
        2000  |
        spark.connection.maxRequest  |
        Maximum number of request connections of JobHistory.  |
        5000  |
