Changing the Password for the OMS Kerberos Administrator
Periodically change the password for the OMS Kerberos administrator kadmin to improve the system O&M security.
If the user password is changed, the Kerberos administrator password is changed as well.
- Log in to the management node using the management IP address as user omm.
 - Run the following command to go to the related directory:
cd ${BIGDATA_HOME}/om-server/om/meta-0.0.1-SNAPSHOT/kerberos/scripts
 - Run the following command to configure environment variables:
source component_env
 - Run the following command to change the password for kadmin/admin. The password changing takes effect on all servers.
kpasswd kadmin/admin
The password complexity requirements are as follows by default:
- The password contains at least 8 characters.
 - The password must contain at least four types of the following: lowercase letters, uppercase letters, digits, and special characters which can only be ~`!?,.;-_'(){}[]/<>@#$%^&*+|\=.
 - The password cannot be the same as the username or reverse username.
 - The password cannot be a common password that is easy to crack, for example, Admin@12345.
 - The password cannot be the same as the password that used in latest N times. N indicates the value of Repetition Rule in Configuring Password Policies.
