Initializing a Password
If a user forgets the password or the public account password needs to be changed periodically, you can initialize the password on FusionInsight Manager. After the password is initialized, the system user needs to change the password upon first login.
   This operation applies only to Human-Machine users.
 - Choose System > Permission > User.
 - Locate the row that contains the user to be initialized, choose More > Initialize Password. In the displayed dialog box, enter the password of the current login user and click OK. In the displayed confirmation dialog box, click OK.
 - Enter a password and confirm the password in New Password and Confirm Password accordingly. Click OK.
By default, the password must meet the following complexity requirements:
- It must contain at least eight characters.
 - The password must contain at least four types of the following characters: Uppercase letters, lowercase letters, digits, spaces, and special characters. The following special characters are supported: `~!@#$%^&*()-_=+|[{}];',<.>/\?
 - It must be different from the username or its reverse.
 - The password cannot be a common password that is easy to crack, for example, Admin@12345.
 - It cannot be the same as the password used in the latest N times. N is the value of Repetition Rule in Configuring Password Policies.
