Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Chart and Add-on/ How Do I Configure the Add-on Resource Quotas Based on Cluster Scale?
After changing the cluster scale, adjust the add-on resource quotas based on the cluster scale to ensure that the add-on pods can run properly. For example, if you expand the cluster scale from 50 worker nodes to 200 worker nodes or more, increase the CPU and memory quotas of the add-on pods to avoid exceptions such as OOM caused by too many nodes required for scheduling the add-on pods.
Configuring Resource Quotas for coredns
Queries per Second (QPS) of the coredns add-on is positively correlated with the CPU consumption. If the number of nodes or containers in the cluster grows, the coredns pod will bear heavier workloads. Adjust the number of add-on pods and their CPU and memory quotas based on the cluster scale.
Table 1 Recommended values for coredns
Nodes
Recommended Configuration (QPS)
Pods
CPU Request (m)
CPU Limit (m)
Memory Request (MiB)
Memory Limit (MiB)
50
2500
2
500
500
512
512
200
5000
2
1000
1000
1024
1024
1000
10000
2
2000
2000
2048
2048
2000
20000
4
2000
2000
2048
2048
Configuring Resource Quotas for everest
After the cluster scale is adjusted, the everest specifications need to be modified based on the cluster scale and the number of PVCs. The requested CPU and memory can be increased based on the number of nodes and PVCs. For details, see Table 2.
In non-typical scenarios, the formulas for estimating the limit values are as follows:
  • everest-csi-controller
    • CPU limit: 250m for 200 or fewer nodes, 350m for 1000 nodes, and 500m for 2000 nodes
    • Memory limit = (200 MiB + Number of nodes x 1 MiB + Number of PVCs x 0.2 MiB) x 1.2
  • everest-csi-driver
    • CPU limit: 300m for 200 or fewer nodes, 500m for 1000 nodes, and 800m for 2000 nodes
    • Memory limit: 300 MiB for 200 or fewer nodes, 600 MiB for 1000 nodes, and 900 MiB for 2000 nodes
Table 2 Recommended configuration limits in typical scenarios
Configuration Scenario
everest-csi-driver
Nodes
PVs/PVCs
Add-on Pods
CPU Cores (Limit = Request)
Memory (Limit = Request)
50
1000
2
250m
600 MiB
300m
300 MiB
200
1000
2
250m
1 GiB
300m
300 MiB
1000
1000
2
350m
2 GiB
500m
600 MiB
1000
5000
2
450m
3 GiB
500m
600 MiB
2000
5000
2
550m
4 GiB
800m
900 MiB
2000
10000
2
650m
5 GiB
800m
900 MiB
Configuring Resource Quotas for autoscaler
autoscaler automatically adjusts the number of nodes in a cluster based on workloads. Adjust the number of add-on pods and their CPU and memory quotas based on the cluster scale.
Table 3 Recommended values for autoscaler
Node
Pod
CPU Request (m)
CPU Limit (m)
Memory Limit (MiB)
50
2
1000
1000
1000
1000
200
2
4000
4000
2000
2000
1000
2
8000
8000
8000
8000
2000
2
8000
8000
8000
8000
Configuring Resource Quotas for volcano
After the cluster scale is increased, the resource quotas required by volcano need to be modified based on the cluster scale.
  • If the number of nodes is less than 100, retain the default configuration. The requested CPU is 500m, and the limit is 2000m. The requested memory is 500 MiB, and the limit is 2000 MiB.
  • If the number of nodes is greater than 100, increase the requested CPU by 500m and the requested memory by 1000 MiB each time 100 nodes (10,000 pods) are added. Increase the CPU limit by 1500m and the memory limit by 1000 MiB.
    Formulas for calculating the requests:
    • CPU request: Calculate the number of nodes multiplied by the number of pods, perform interpolation search using the product of the number of nodes in the cluster multiplied by the number of pods in Table 4, and round up the request and limit which are closest to the specifications.
      For example, for 2000 nodes (20,000 pods), the product of the number of nodes multiplied by the number of pods is 40 million, which is close to 700/70,000 in the specification (Number of nodes x Number of pods = 49 million). Set the CPU request to 4000m and the limit to 5500m.
    • Memory request: Allocate 2.4 GiB of memory to every 1000 nodes and 1 GiB of memory to every 10,000 pods. The memory request is the sum of the two values. (The obtained value may be different from the recommended value in Table 4. You can use either of them.)
      Memory request = Number of nodes/1000 x 2.4 GiB + Number of pods/10000 x 1 GiB
      For example, for 2000 nodes and 20,000 pods, the memory request value is 6.8 GiB (2000/1000 x 2.4 GiB + 20000/10000 x 1 GiB).
Table 4 Recommended requested resources and resource limits for volcano-controller and volcano-scheduler
Nodes/Pods in a Cluster
CPU Request (m)
CPU Limit (m)
Memory Limit (MiB)
50/5000
500
2000
500
2000
100/10000
1000
2500
1500
2500
200/20000
1500
3000
2500
3500
300/30000
2000
3500
3500
4500
400/40000
2500
4000
4500
5500
500/50000
3000
4500
5500
6500
600/60000
3500
5000
6500
7500
700/70000
4000
5500
7500
8500
Configuring Resource Quotas for Other Add-ons
Resource quotas of other add-ons may also be insufficient due to cluster scale expansion. If, for example, the CPU or memory usage of the add-on pods increases and even OOM occurs, modify the resource quotas as required.
For example, the resources occupied by the Cloud Native Cluster Monitoring add-on are related to the number of pods in the cluster. If the cluster scale is expanded, the number of pods may also grow. In this case, increase the resource quotas of the add-on pods.
