What Is a Headless Service When I Create a StatefulSet?
The inter-pod discovery service of CCE corresponds to the headless Service of Kubernetes. Headless Services specify None for the cluster IP (spec:clusterIP) in YAML, which means no cluster IP is allocated.
Differences Between Headless Services and Common Services
- Common Services:
    One Service may be backed by multiple endpoints (pods). A client accesses the cluster IP address and the request is forwarded to the real server based on the iptables or IPVS rules to implement load balancing. For example, a Service has two endpoints, but only the Service address is returned during DNS query. The iptables or IPVS rules determine the real server that the client accesses. The client cannot access the specified endpoint.
Headless Service Application Scenarios
If there is no difference between multiple pods of a workload, you can use a common Service and use the cluster kube-proxy to implement load balancing, for example, an Nginx Deployment.
However, in some application scenarios, pods of a workload have different roles. For example, in a Redis cluster, each Redis pod is different. They have a master/slave relationship and need to communicate with each other. In this case, a common Service cannot access a specified pod through the cluster IP address. Therefore, you need to allow the headless Service to directly access the real IP address of the pod to implement mutual access among pods.
Headless Services work with StatefulSet to deploy stateful applications, such as Redis and MySQL.
