Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ FAQs/ Node/ Node Creation/ What Should I Do If a Node Cannot Be Managed and an Error Message Appears Saying That the Node Failed to Install?
Symptom
A node fails to be accepted into a cluster.
Possible Cause
Log in to the node and check the /var/paas/sys/log/baseagent/baseagent.log installation log. The following error information is displayed:
Check the Logical Volume Manager (LVM) settings of the node. It is found that the LVM logical volume is not created in /dev/vdb.
Solution
Run the following command to manually create a logical volume:
pvcreate /dev/vdb
vgcreate vgpaas /dev/vdb
After the node is reset on the GUI, the node becomes normal.
