How Can I Configure a Security Group Rule for a Cluster?
CCE is a universal container platform. Its default security group rules apply to common scenarios. When a cluster is created, a security group is automatically created for the master nodes and worker nodes, separately. The name of the master node security group is in the format of {Cluster name}-cce-control-{Random ID}, and that of the worker node security group is in the format of {Cluster name}-cce-node-{Random ID}. For a CCE Turbo cluster, an additional ENI security group, with the name following the format of {Cluster name}-cce-eni-{Random ID}, will be created.
To modify the security group rules, log in to the management console and choose Service List > Networking > Virtual Private Cloud. On the page displayed, choose Access Control > Security Groups in the navigation pane, locate the rpw containing the target security group, and modify the rules.
You can check the default security group rules of clusters using different network models in:
- Security Group Rules in a Cluster That Uses the VPC Network Model
- Security Group Rules in a Cluster That Uses the Tunnel Network Model
- Security Group Rules in a CCE Turbo Cluster That Uses the Cloud Native 2.0 Network Model
- Be careful when modifying or removing security group rules as it could impact the cluster's operation. Avoid modifying the rules for the ports essential to CCE.
- When adding a security group rule, ensure that this rule does not conflict with the existing rules. If there is a conflict, existing rules may become invalid, affecting cluster running.
Worker node security group
A security group, with a name following the format of {Cluster name}-cce-node-{Random ID}, is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 1.
Direction |
Port |
Default Source Address |
Description |
Modification Suggestion |
Impact After Modification |
Inbound rules |
All UDP ports |
VPC CIDR block |
Allow access between the worker nodes and between the worker nodes and the master nodes. |
Modification not recommended |
If the configuration is modified, the cluster will not function correctly. |
All TCP ports |
All ICMP ports |
Master node security group |
Allow the master nodes to access the worker nodes. |
TCP port range: 30000 to 32767 |
All IP addresses (0.0.0.0/0) |
Allow access from the NodePort Services. |
Modification made if necessary |
The ports must allow traffic from the CIDR blocks of the VPC, container, and load balancer. |
UDP port range: 30000 to 32767 |
All |
Container CIDR block |
Allow containers within the cluster to access the nodes. |
All |
Worker node security group |
Restrict access from outside the worker node security group, but the access between pods in the worker node security group. |
TCP port 22 |
Allow SSH access to Linux ECSs. |
Modification recommended |
You are advised to allow access only from fixed IP addresses or IP address ranges. |
Outbound rule |
All |
Allow traffic on all ports by default. You are advised to retain this setting. |
If you want to harden security by allowing traffic only on specific ports, remember to allow such ports. For details, see Hardening Outbound Rules. |
A security group, with a name following the format of {Cluster name}-cce-control-{Random ID}, is automatically created for the master nodes in a cluster. For details about the default ports, see Table 2.
Direction |
Port |
Description |
Inbound rules |
TCP port 5444 |
VPC CIDR block |
Allow access from kube-apiserver, which provides lifecycle management for Kubernetes resources. |
TCP port 5444 |
TCP port 9443 |
VPC CIDR block |
Allow the network add-on of the worker nodes to access the master nodes. |
TCP port 5443 |
Allow kube-apiserver of the master nodes to listen to the worker nodes. |
The port must allow traffic from the CIDR blocks of the VPC, the control plane of the hosted service mesh, and container. |
TCP port 8445 |
VPC CIDR block |
Allow the storage add-on of the worker nodes to access the master nodes. |
All |
Restrict access from outside the master node security group, but the access between pods in the master node security group. |
Outbound rule |
All |
Allow traffic on all ports by default. |
A security group, with a name following the format of {Cluster name}-cce-node-{Random ID}, is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 3.
Direction |
Port |
Description |
Inbound rules |
UDP port 4789 |
Allow access between containers. |
TCP port 10250 |
Master node CIDR block |
Allow the master nodes to access kubelet on the worker nodes to run commands, for example, kubectl exec {pod}. |
The ports must allow traffic from the CIDR blocks of the VPC, load balancer, and container. |
TCP port 22 |
All |
Outbound rule |
All |
A security group, with a name following the format of {Cluster name}-cce-control-{Random ID}, is automatically created for the master nodes in a cluster. For details about the default ports, see Table 4.
Direction |
Port |
Description |
Inbound rules |
UDP port 4789 |
TCP port 5444 |
VPC CIDR block |
TCP port 5444 |
TCP port 9443 |
VPC CIDR block |
TCP port 5443 |
TCP port 8445 |
VPC CIDR block |
All |
Outbound rule |
All |
A security group, with a name following the format of {Cluster name}-cce-node-{Random ID}, is automatically created for the worker nodes in a cluster. For details about the default ports, see Table 5.
Direction |
Port |
Description |
Inbound rules |
TCP port 10250 |
TCP port 22 |
All |
All |
Container subnet CIDR block |
Outbound rule |
All |
A security group, with a name following the format of {Cluster name}-cce-control-{Random ID}, is automatically created for the master nodes in a cluster. For details about the default ports, see Table 6.
Direction |
Port |
Description |
Inbound rules |
TCP port 5444 |
TCP port 5444 |
VPC CIDR block |
TCP port 9443 |
VPC CIDR block |
TCP port 5443 |
TCP port 8445 |
VPC CIDR block |
All |
All |
Allow traffic from all source IP addresses in the container subnet CIDR block. |
Outbound rule |
All |
ENI security group
In a CCE Turbo cluster, an additional security group, with the name following the format of {Cluster name}-cce-eni-{Random ID}, is created. By default, containers in the cluster are bound to this security group. For details about the default ports, see Table 7.
Direction |
Port |
Description |
Inbound rules |
All |
ENI security group |
Allow containers within the cluster to access each other. |
VPC CIDR block |
Allow instances in the cluster VPC to access the containers. |
Outbound rule |
All |
By default, all security groups created by CCE allow all the outbound traffic. You are advised to retain this configuration. To harden outbound rules, ensure that the traffic on the ports listed in the following table is allowed.
Port |
Allowed CIDR |
Description |
UDP port 53 |
DNS server of the subnet |
Allow traffic on the port for domain name resolution. |
UDP port 5353 |
Allow traffic on the port for CoreDNS domain name resolution. |
UDP port 4789 (required only by clusters that use the tunnel networks) |
All IP addresses |
TCP port 5443 |
TCP port 5444 |
CIDR blocks of the VPC and containers |
TCP port 6443 |
None |
TCP port 8445 |
VPC CIDR block |
TCP port 9443 |
VPC CIDR block |
All ports |
198.19.128.0/17 |
Allow access to VPC Endpoint (VPCEP). |
UDP port 123 |
100.125.0.0/16 |
Allow the worker nodes to access the internal NTP server. |
TCP port 443 |
100.125.0.0/16 |
Allow the worker nodes to access OBS over internal networks to pull the installation package. |
TCP port 6443 |
100.125.0.0/16 |
Allow the worker nodes to report that the worker nodes have been installed. |
