How Do I Locate the Fault When a Cluster Is Unavailable?
This section provides you with some operations to locate the fault when a cluster becomes unavailable.
Troubleshooting
The issues here are described in order of how likely they are to occur.
Check these causes one by one until you find the cause of the fault.
- Check Item 1: Whether the Security Group Is Modified
- Check Item 2: Whether the Cluster Is Overloaded
If the fault persists, contact the customer service to help you locate the fault.
- Log in to the management console and choose Service List > Networking > Virtual Private Cloud. In the navigation pane, choose Access Control > Security Groups and find the security group of the master node in the cluster.
    The name of this security group is in the format of Cluster name-cce-control-ID.
- Click the security group. On the details page displayed, ensure that the security group rules of the master node are correct.
    For details, see How Can I Configure a Security Group Rule for a Cluster?
Symptom
The resource usage on the master nodes in the cluster reaches 100%.
Possible cause
When a cluster has a large number of resources created simultaneously, it causes an overload on the API server. This, in turn, overloads the master nodes and leads to OOM issues.
Solution
Increase the cluster management scale. A larger cluster management scale means higher capacity and improved performance of the master nodes. For details, see Changing Cluster Scale.
If a cluster is overloaded, you can submit a service ticket for technical support.
