What Are the Differences Among CCE Storage Classes in Terms of Persistent Storage and Multi-Node Mounting?
Container storage provides storage for container workloads. It supports multiple storage classes. A pod can use any amount of storage.
Currently, CCE supports local, EVS, SFS, SFS Turbo, and OBS volumes.
The following table lists the differences among these storage classes.
Storage Class |
Persistent Storage |
Automatic Migration with Containers |
Multi-Node Mounting |
Local disks |
Supported |
Not supported |
Not supported |
EVS |
Supported |
Supported |
Not supported |
OBS |
Supported |
Supported |
Supported. This type of volumes can be shared among multiple nodes or workloads. |
SFS Turbo |
Supported |
Supported |
Dedicated Distributed Storage Service (DSS) |
Supported |
Supported |
Not supported |
Selecting a Storage Class
You can use the following types of storage volumes when creating a workload. You are advised to store workload data on EVS volumes. If you store workload data on a local volume, the data cannot be restored when a fault occurs on the node.
- Local volumes: Mount the file directory of the host where a container is located to a specified container path (corresponding to hostPath in Kubernetes). Alternatively, you can leave the source path empty (corresponding to emptyDir in Kubernetes). If the source path is left empty, a temporary directory of the host will be mounted to the mount point of the container. A specified source path is used when data needs to be persistently stored on the host, while emptyDir is used when temporary storage is needed. A ConfigMap is a type of resource that stores configuration data required by a workload. Its contents are user-defined. A secret is an object that contains sensitive data such as workload authentication information and keys. Information stored in a secret is determined by users.
- EVS volumes: Mount an EVS volume to a container path. When the container is migrated, the mounted EVS volume is migrated together. This storage class is applicable when data needs to be stored permanently.
- OBS volumes: Create OBS volumes and mount them to a container path. OBS volumes are applicable to scenarios such as cloud workload, data analysis, content analysis, and hotspot objects.
- SFS Turbo volumes: Create SFS Turbo volumes and mount them to a container path. SFS Turbo volumes are fast, on-demand, and scalable, which makes them suitable for DevOps, containerized microservices, and enterprise office applications.
- DSS volumes: CCE allows you to create DSS volumes and mount them to a container path. DSS offers dedicated, physical storage resources tailored to fulfill the needs of high-performance and low-latency storage. It is ideal for scenarios such as high-performance computing, real-time analysis and processing, and handling mixed workloads.
