Using Custom Storage Classes
Background
When using storage resources in CCE, the most common method is to specify storageClassName to define the type of storage resources to be created when creating a PVC. The following configuration shows how to use a PVC to apply for an SAS (high I/O) EVS disk (block storage).
apiVersion: v1
kind: PersistentVolumeClaim
  namespace: default
  annotations:
    everest.io/disk-volume-type: SAS
  accessModes:
  - ReadWriteOnce
  resources:
    requests:
      storage: 10Gi
  storageClassName: csi-disk
To specify the EVS disk type, you can configure the everest.io/disk-volume-type field. The value SAS is used as an example here, indicating the high I/O EVS disk type. Or you can choose SSD (ultra-high I/O).
This configuration method may not work if you want to:
  • Set storageClassName only, which is simpler than specifying the EVS disk type by using everest.io/disk-volume-type.
  • Avoid modifying YAML files or Helm charts. Some users switch from self-built or other Kubernetes services to CCE and have written YAML files of many applications. In these YAML files, different types of storage resources are specified by different StorageClassNames. When using CCE, they need to modify a large number of YAML files or Helm charts to use storage resources, which is labor-consuming and error-prone.
  • Set the default storageClassName for all applications to use the default storage class. In this way, you can create storage resources of the default type without needing to specify storageClassName in the YAML file.
Solution
This section describes how to set a custom storage class in CCE and how to set the default storage class. You can specify different types of storage resources by setting storageClassName.
  • For the first scenario, you can define custom storageClassNames for SAS and SSD EVS disks. For example, define a storage class named csi-disk-sas for creating SAS disks. The following figure shows the differences before and after you use a custom storage class.
  • For the second scenario, you can define a storage class with the same name as that in the existing YAML file without needing to modify storageClassName in the YAML file.
  • For the third scenario, you can set the default storage class as described below to create storage resources without specifying storageClassName in YAML files.
    apiVersion: v1
      namespace: default
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
Creating a StorageClass Using a YAML File
As of now, CCE provides StorageClasses such as csi-disk, csi-nas, and csi-obs by default. When defining a PVC, you can use a StorageClassName to automatically create a PV of the corresponding type and automatically create underlying storage resources.
Run the following kubectl command to obtain the StorageClasses that CCE supports. Use the CSI add-on provided by CCE to create a StorageClass.
# kubectl get sc
NAME                PROVISIONER                     AGE
csi-disk            everest-csi-provisioner         17d          # EVS disk
csi-disk-topology   everest-csi-provisioner         17d          # EVS disks created with delay
csi-nas             everest-csi-provisioner         17d          # SFS 1.0
csi-obs             everest-csi-provisioner         17d          # OBS
csi-sfsturbo        everest-csi-provisioner         17d          # SFS Turbo
csi-disk-dss        everest-csi-provisioner         2d21h        # DSS
Each StorageClass contains the default parameters used for dynamically creating a PV. The following is an example of StorageClass for EVS disks:
kind: StorageClass
apiVersion: storage.k8s.io/v1
provisioner: everest-csi-provisioner
parameters:
  csi.storage.k8s.io/csi-driver-name: disk.csi.everest.io
  csi.storage.k8s.io/fstype: ext4
  everest.io/passthrough: 'true'
reclaimPolicy: Delete
allowVolumeExpansion: true
volumeBindingMode: Immediate
Table 1 Key parameters
provisioner
Specifies the storage resource provider, which is the Everest add-on for CCE. Set this parameter to everest-csi-provisioner.
parameters
Specifies the storage parameters, which vary with storage types. For details, see Table 2.
reclaimPolicy
Specifies the value of persistentVolumeReclaimPolicy for creating a PV. The value can be Delete or Retain. If reclaimPolicy is not specified when a StorageClass object is created, the value defaults to Delete.
  • Delete: When a PVC is deleted, its associated underlying storage resources will be deleted and the PV resources will be removed. Exercise caution if you select this option.
  • Retain: When a PVC is deleted, both of the PV and its associated underlying storage resources will be retained and the PV is marked as released. If you manually delete the PV afterwards, the underlying storage resources will not be deleted. To bind the PV to a new PVC, you need to remove the original binding information from the PV.
Specifies whether the PV of this StorageClass supports dynamic capacity expansion. The default value is false. Dynamic capacity expansion is implemented by the underlying storage add-on. This is only a switch.
volumeBindingMode
Specifies the volume binding mode, which is the time when a PV is dynamically created. The value can be Immediate or WaitForFirstConsumer.
  • Immediate: After a PVC is created, the storage resources and PV will be created and associated with the PVC without delay.
  • WaitForFirstConsumer: After a PVC is created, it will not be immediately bound to a PV. Instead, the storage resources and PV will be generated and bound to the PVC only after the pod that requires the PVC is scheduled.
mountOptions
This field must be supported by the underlying storage. If this field is not supported but is specified, the PV creation will fail.
Table 2 Parameters
Volume Type
Mandatory
EVS
Yes
Driver type. If an EVS disk is used, the parameter value is fixed at disk.csi.everest.io.
EVS
Yes
If an EVS disk is used, the parameter value can be ext4.
EVS
Yes
EVS disk type. All letters are in uppercase.
  • SAS: high I/O
  • SSD: ultra-high I/O
EVS
Yes
The parameter value is fixed at true, which indicates that the EVS device type is SCSI. No other parameter values are allowed.
SFS Turbo
Yes
Driver type. If SFS Turbo is used, the parameter value is fixed at sfsturbo.csi.everest.io.
SFS Turbo
Yes
If SFS Turbo is used, the value can be nfs.
SFS Turbo
everest.io/share-access-to
Yes
VPC ID of the cluster.
SFS Turbo
everest.io/share-expand-type
No
Extension type. The default value is bandwidth, indicating an enhanced file system. This parameter does not take effect.
SFS Turbo
everest.io/share-source
Yes
The parameter value is fixed at sfs-turbo.
SFS Turbo
everest.io/share-volume-type
No
SFS Turbo StorageClass. The default value is STANDARD, indicating standard and standard enhanced editions. This parameter does not take effect.
SFS Turbo
everest.io/reclaim-policy
No
Whether to retain subdirectories when deleting a PVC. This parameter must be used with reclaim policies. This parameter is available only when the PV reclaim policy is Delete. Options:
  • retain-volume-only: If a PVC is deleted, the PV will be deleted, but its associated subdirectories will be retained.
  • delete: When a PVC is deleted, the associated PV and its subdirectories will also be deleted.
    When a subdirectory is deleted, only the absolute path of the subdirectory configured in the PVC will be deleted. The upper-layer directory will not be deleted.
OBS
Yes
Driver type. If OBS is used, the parameter value is fixed at obs.csi.everest.io.
OBS
Yes
Instance type, which can be obsfs or s3fs.
  • obsfs: a parallel file system
  • s3fs: object bucket
OBS
everest.io/obs-volume-type
Yes
OBS StorageClass.
  • If fsType is set to s3fs, standard buckets (STANDARD) and infrequent access buckets (WARM) are supported.
  • This parameter is invalid when fsType is set to obsfs.
DSS
Yes
Driver type. If DSS is used, the parameter value is fixed at disk.csi.everest.io.
DSS
Yes
File system type. The value can only be ext4.
DSS
Yes
Dedicated storage, which must be specified in uppercase.
  • SAS: high I/O
DSS
Yes
The parameter value is fixed at true, indicating that the DSS device type is SCSI. No other values are allowed.
DSS
everest.io/resource-type
Yes
Resource type. The parameter value is fixed at dss.
You can customize a high I/O storage class in a YAML file. For example, the name csi-disk-sas indicates that the disk type is SAS (high I/O).
kind: StorageClass
  name: csi-disk-sas                          # Name of the high I/O storage class, which can be customized.
parameters:
  everest.io/disk-volume-type: SAS            # High I/O EVS disk type, which cannot be customized.
  everest.io/passthrough: "true"
allowVolumeExpansion: true                    # true indicates that capacity expansion is allowed.
For an ultra-high I/O storage class, you can set the class name to csi-disk-ssd to create SSD EVS disk (ultra-high I/O).
kind: StorageClass
  name: csi-disk-ssd                       # Name of the ultra-high I/O storage class, which can be customized.
parameters:
  everest.io/disk-volume-type: SSD         # Ultra-high I/O EVS disk type, which cannot be customized.
reclaimPolicy: indicates the recycling policies of the underlying cloud storage. The value can be Delete or Retain.
  • Delete: When a PVC is deleted, both the PV and the EVS disk are deleted.
  • Retain: When a PVC is deleted, the PV and underlying storage resources are not deleted. Instead, you must manually delete these resources. After that, the PV resource is in the Released state and cannot be bound to the PVC again.
The reclamation policy configured here has no impact on the SFS Turbo storage.
If high data security is required, you are advised to select Retain to prevent data from being deleted by mistake.
After the definition is complete, run the kubectl create commands to create storage resources.
# kubectl create -f sas.yaml
storageclass.storage.k8s.io/csi-disk-sas created
# kubectl create -f ssd.yaml
storageclass.storage.k8s.io/csi-disk-ssd created
Query the storage class again. Two more types of storage classes are displayed in the command output, as shown below.
# kubectl get sc
csi-disk-sas        everest-csi-provisioner         2m28s
csi-disk-ssd        everest-csi-provisioner         16s
Other types of storage resources can be defined in the similar way. You can use kubectl to obtain the YAML file and modify it as required.
  • File storage
    # kubectl get sc csi-nas -oyaml
    kind: StorageClass
    parameters:
      csi.storage.k8s.io/csi-driver-name: nas.csi.everest.io
      csi.storage.k8s.io/fstype: nfs
      everest.io/share-access-level: rw
      everest.io/share-access-to: 5e3864c6-e78d-4d00-b6fd-de09d432c632   # ID of the VPC to which the cluster belongs
      everest.io/share-is-public: 'false'
      everest.io/zone: xxxxx          # AZ
  • Object storage
    # kubectl get sc csi-obs -oyaml
    kind: StorageClass
    parameters:
      csi.storage.k8s.io/csi-driver-name: obs.csi.everest.io
      csi.storage.k8s.io/fstype: s3fs           # Object storage type. s3fs indicates an object bucket, and obsfs indicates a parallel file system.
      everest.io/obs-volume-type: STANDARD      # Storage class of the OBS bucket
Specifying an Enterprise Project for Storage Classes
CCE allows you to specify an enterprise project when creating EVS disks and OBS PVCs. The created storage resources (EVS disks and OBS) belong to the specified enterprise project. The enterprise project can be the enterprise project to which the cluster belongs or the default enterprise project.
If you do not specify any enterprise project, the enterprise project in StorageClass is used by default. The created storage resources by using the csi-disk and csi-obs storage classes of CCE belong to the default enterprise project.
If you want the storage resources created from the storage classes to be in the same enterprise project as the cluster, you can customize a storage class and specify the enterprise project ID, as shown below.
To use this function, the everest add-on must be upgraded to 1.2.33 or later.
kind: StorageClass
  name: csi-disk-epid      #Customize a storage class name.
parameters:
  everest.io/enterprise-project-id: 86bfc701-9d9e-4871-a318-6385aa368183  #Specify the enterprise project ID.
Specifying a Default Storage Class
You can specify a storage class as the default class. In this way, if you do not specify storageClassName when creating a PVC, the PVC is created using the default storage class.
For example, to specify csi-disk-ssd as the default storage class, edit your YAML file as follows:
kind: StorageClass
  annotations:
    storageclass.kubernetes.io/is-default-class: "true"   # Specifies the default storage class in a cluster. A cluster can have only one default storage class.
parameters:
Delete the created csi-disk-ssd disk, run the kubectl create command to create a csi-disk-ssd disk again, and then query the storage class. The following information is displayed.
# kubectl delete sc csi-disk-ssd
storageclass.storage.k8s.io "csi-disk-ssd" deleted
# kubectl get sc
csi-disk-sas             everest-csi-provisioner         114m
csi-disk-ssd (default)   everest-csi-provisioner         9s
Verification
When creating a PVC, you have the following configuration methods:
  • Specify a storage class explicitly.
  • Use the default storage class set up in the cluster if you do not specify a storage class.
Below are the steps to check the results of both configuration methods.
The following steps are used to verify whether the storage class csi-disk-sas defined in Custom Storage Classes can be used to create a PVC.
  1. Create a YAML file named sas-disk.yaml. You can change the file name as needed. This file uses csi-disk-sas to create a PVC.
    vim sas-disk.yaml
    The file content is as follows:
    apiVersion: v1
      accessModes:
      - ReadWriteOnce
      resources:
        requests:
          storage: 10Gi
      storageClassName: csi-disk-sas
  2. Create a PVC.
    kubectl create -f sas-disk.yaml
    Information similar to the following is displayed:
    persistentvolumeclaim/sas-disk created
  3. Check the PVC information.
    kubectl get pvc
    If information similar to the following is displayed, a PV has been associated with the PVC and the storage class is csi-disk-sas.
    NAME       STATUS   VOLUME                                     CAPACITY   ACCESS MODES   STORAGECLASS   AGE
    sas-disk   Bound    pvc-6e2f37f9-7346-4419-82f7-b42e79f7964c   10Gi       RWO            csi-disk-sas   24s
  4. Check the PV information.
    kubectl get pv
    If information similar to the following is displayed, the PV has been automatically created.
    NAME                                       CAPACITY   ACCESS MODES   RECLAIM POLICY   STATUS      CLAIM                     STORAGECLASS   REASON   AGE
    pvc-6e2f37f9-7346-4419-82f7-b42e79f7964c   10Gi       RWO            Delete           Bound       default/sas-disk          csi-disk-sas            30s
    The result shows that the custom storage class csi-disk-sas can be used properly.
