Help Center/ Cloud Container Engine/ User Guide (ME-Abu Dhabi Region)/ Workloads/ Scheduling a Workload/ Configuring Specified Node Scheduling (nodeSelector)
To select a node for scheduling in Kubernetes, simply configure the nodeSelector field in the workload. This field allows you to configure the label of the desired node to be scheduled. Kubernetes schedules pods only to nodes with specified labels.
A custom label has been added to the target node so that workload pods can be scheduled based on the node label. For details, see Adding or Deleting a Node Label.
Creating a Workload Scheduled to a Specified Node
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Create a YAML file named nginx.yaml. The file name can be customized.
    Configure nodeSelector for the workload. For example, if the key is deploy_qa and the value is true, the pod will be scheduled to the node with the deploy_qa=true label. Example:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          nodeSelector:
            deploy_qa: "true"
          containers:
          - image: nginx:latest
            imagePullPolicy: IfNotPresent
          imagePullSecrets:
          - name: default-secret
  3. Create a workload.
    kubectl apply -f nginx.yaml
  4. Verify that all pods run on the target node.
    kubectl get pod -o wide
    In the following command output, node 192.168.0.103 is labeled with deploy_qa=true:
    NAME                     READY   STATUS    RESTARTS   AGE     IP              NODE                                   NOMINATED NODE   READINESS GATES
    nginx-66859f4f48-xgp2g   1/1     Running   0          6h57m   172.16.3.0   192.168.0.103   <none>           <none>
    nginx-66859f4f48-t9gqj   1/1     Running   0          6h57m   172.16.3.1   192.168.0.103   <none>           <none>
    nginx-66859f4f48-2grhq   1/1     Running   0          6h57m   172.16.3.2   192.168.0.103   <none>           <none>
