Configuring a Cluster's API Server for Internet Access
You can bind an EIP to an API server of a Kubernetes cluster so that the API server can access the Internet.
- On the Overview page, locate the Connection Information area, and click Bind next to EIP.
- Select an existing EIP. If no EIP is available, click Create EIP to go to the EIP console and assign one.
- Binding an EIP to an API server for Internet access can pose a risk to the cluster's security. To mitigate this risk, configure Advanced Anti-DDoS or API server access policies (Configuring Access Policies for an API Server) for the bound EIP.
- Binding an EIP to an API server will cause the API server to restart briefly and update the kubeconfig certificate. Do not make any changes to the cluster during this period.
- Click OK. The bound EIP will be displayed in EIP.
To ensure the security of a cluster's API server, it is important to modify the security group rules for the master nodes. This is because the EIP, which is exposed to the Internet, is at risk of being attacked.
- Log in to the CCE console and click the cluster name to access the cluster console. On the Overview page, find and copy the cluster ID.
- Log in to the VPC console. In the navigation pane, choose Access Control > Security Groups.
- Select Description as the filter criterion and search for the target security group by cluster ID.
- Locate the row that contains the security group (starting with {CCE cluster name}-cce-control) of the master node and click Manage Rules in the Operation column.
- On the page displayed, locate the row that contains port 5443 and click Modify in the Operation column to modify its inbound rules.
- Change the source IP address that can be accessed as required. For example, if the IP address used by the client to access the API Server is 100.*.*.*, you can add an inbound rule for port 5443 and set the source IP address to 100.*.*.*.
In addition to the client IP address, the port must allow traffic from the CIDR blocks of the VPC, container, and the control plane of the hosted service mesh to ensure that the API Server can be accessed from within the cluster.
- Click Confirm.
