Configuring an EIP for a Pod
Application Scenarios
In Cloud Native Network 2.0, pods use VPC ENIs or sub-ENIs for networking. You can directly bind EIPs to pods.
To associate an EIP with a pod, simply set the value of the yangtse.io/pod-with-eip annotation to true when creating the pod. Then, the EIP will be automatically allocated and bound to the pod.
A CCE Turbo cluster is available and the cluster version meets the requirements listed in the following table.
Cluster Version
Allocating an EIP with a pod
  • v1.19: v1.19.16-r20 or later
  • v1.21: v1.21.10-r0 or later
  • v1.23: v1.23.8-r0 or later
  • v1.25: v1.25.3-r0 or later
  • Versions later than v1.25
Using an existing EIP for a pod
v1.23: v1.23.16-r0 or later
v1.25: v1.25.11-r0 or later
v1.27: v1.27.8-r0 or later
v1.28: v1.28.6-r0 or later
v1.29: v1.29.2-r0 or later
Versions later than v1.29
Notes and Constraints
  • To access a pod bound with an EIP from the Internet, add security group rules to allow the target request traffic.
  • Only one EIP can be bound to a pod.
  • Configure the EIP-related annotation when creating a pod. After the pod is created, the annotations related to the EIP cannot be modified.
  • Do not perform operations on the EIP associated with a pod through the EIP console or API. Otherwise, the EIP may malfunction. The operations include changing the EIP name, and deleting, unbinding, or binding the EIP.
  • After an automatically allocated EIP is manually deleted, the network malfunctions. In this case, rebuild the pod.
Allocating an EIP with a Pod
If you set the pod-with-eip annotation to true when creating a pod, an EIP will be automatically allocated and bound to the pod.
  • CCE will automatically add cluster ID, namespace, and pod name labels to an EIP that has been allocated automatically.
  • If a pod is created with an automatically allocated EIP, deleting the pod will also delete the EIP.
The following uses a Deployment named nginx as an example. For details about annotations, see Table 2.
  • For an automatically allocated EIP with a dedicated bandwidth when you create a Deployment, you do not need to specify the bandwidth ID. The following shows an example:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/pod-with-eip: "true"  # An EIP will be automatically allocated when the pod is created.
            yangtse.io/eip-bandwidth-size: "5"  # EIP bandwidth
            yangtse.io/eip-network-type: 5_bgp  # EIP type
            yangtse.io/eip-charge-mode: bandwidth  # EIP billing mode
            yangtse.io/eip-bandwidth-name: <eip_bandwidth_name>  # EIP bandwidth name
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
            - name: default-secret
    Table 1 Annotations of an EIP with a dedicated bandwidth
    Annotation
    Mandatory
    Default Value
    Value Range
    Yes
    false
    Whether to allocate an EIP with a pod and bind the EIP to the pod
    false or true
    No
    5
    Bandwidth, in Mbit/s
    The value range varies depending on the region and bandwidth billing mode. For details, see the page on the EIP console.
    No
    5_bgp
    EIP type
    The type varies depending on the region. For details, see the page on the EIP console.
    No
    None
    Billed by traffic or bandwidth
    You are advised to configure this parameter. If this parameter is left blank, no billing mode is specified. In this case, the default value of the EIP API in the region is used.
    • bandwidth: billed by bandwidth
    • traffic: billed by traffic
    No
    Pod name
    Bandwidth name
    • Enter 1 to 64 characters. Only letters, digits, hyphens (-), underscores (_), and periods (.) are allowed.
    • Minimum length: 1 character
    • Maximum length: 64 characters
  • For an automatically allocated EIP with a shared bandwidth when you create a Deployment, you are required to specify the bandwidth ID. The following shows an example:
    apiVersion: apps/v1
    kind: Deployment
      replicas: 3
      selector:
        matchLabels:
          app: nginx
      template:
          labels:
            app: nginx
          annotations:
            yangtse.io/eip-bandwidth-id: <eip_bandwidth_id>  # Shared bandwidth ID of the EIP
          containers:
            - name: container-0
              image: nginx:alpine
              resources:
                limits:
                  cpu: 100m
                  memory: 200Mi
                requests:
                  cpu: 100m
                  memory: 200Mi
          imagePullSecrets:
    Table 2 Annotations of an EIP with a shared bandwidth
    Annotation
    Mandatory
    Default Value
    Value Range
    Yes
    false
    false or true
    No
    5_bgp
    EIP type
    • 5_bgp
    The specific type varies with regions. For details, see the EIP console.
    Mandatory when a shared bandwidth is used
    None
    ID of an existing bandwidth
    • If this parameter is not specified, the EIP with a dedicated bandwidth is used by default. For details about how to configure parameters for an EIP with a dedicated bandwidth, see Table 1.
    • Only the yangtse.io/eip-network-type field can be specified concurrently, and this field is optional.
    None
Using an Existing EIP for a Pod
If you configure the yangtse.io/eip-id annotation when creating a pod, the EIP will be automatically bound to the pod.
  • After an existing EIP is bound to a pod, CCE will automatically add the cluster ID, namespace, and pod name labels to the EIP.
  • When a pod using an existing EIP is deleted, the EIP will be retained. CCE will automatically delete the labels for the cluster ID, namespace, and pod name that were added when the EIP was bound.
The following example shows how to create a Deployment named nginx with a single pod with an EIP automatically bound.
apiVersion: apps/v1
kind: Deployment
  replicas: 1
  selector:
    matchLabels:
      app: nginx
  template:
      labels:
        app: nginx
      annotations:
        yangtse.io/eip-id: <eip_id> # ID of an existing EIP
      containers:
        - name: container-0
          image: nginx:alpine
          resources:
            limits:
              cpu: 100m
              memory: 200Mi
            requests:
              cpu: 100m
              memory: 200Mi
      imagePullSecrets:
Table 3 Annotations for using an existing EIP
Annotation
Mandatory
yangtse.io/eip-id
Yes
EIP ID
How to obtain:
Log in to the EIP console, click the name of the target EIP in the EIP list, and copy the ID field.
Checking Whether the EIP Bound to the Pod Is Available
After an EIP is allocated to a pod, the container networking controller binds the EIP to the pod and writes the allocation result back to the pod's yangtse.io/allocated-ipv4-eip annotation. The startup time of the pod's service containers may be earlier than the time when the EIP allocation result is written back.
You can configure an init container for the pod, associate the yangtse.io/allocated-ipv4-eip annotation with the init container through a downwardAPI volume, and check whether the EIP has been allocated in the init container. You can configure the init container as follows:
apiVersion: v1
kind: Pod
  annotations:
    yangtse.io/eip-bandwidth-name: "xxx"
  initContainers:
  - name: init
    image: busybox:latest
    command: ['timeout', '60', 'sh', '-c', "until grep -E '[0-9]+' /etc/eipinfo/allocated-ipv4-eip; do echo waiting for allocated-ipv4-eip; sleep 2; done"]
    volumeMounts:
        - name: eipinfo
          mountPath: /etc/eipinfo
  volumes:
    - name: eipinfo
      downwardAPI:
        items:
          - path: "allocated-ipv4-eip"
            fieldRef:
              fieldPath: metadata.annotations['yangtse.io/allocated-ipv4-eip']
