Annotations for Configuring Nginx Ingresses
The nginx-ingress add-on in CCE uses the community chart and image. If the default add-on parameters cannot meet your demands, you can add annotations to define what you need, such as the default backend, timeout, and size of a request body.
This section describes common annotations used for creating an ingress of the Nginx type.
  • The key value of an annotation can only be a string. Other types (such as Boolean values or numeric values) must be enclosed in quotation marks (""), for example, "true", "false", and "100".
  • Nginx Ingress supports native annotations of the community. For details, see Annotations.
Ingress Type
Table 1 Ingress type annotations
Type
Supported Cluster Version
kubernetes.io/ingress.class
String
  • nginx: Nginx Ingress is used.
  • cce: A proprietary LoadBalancer ingress is used.
This parameter is mandatory when an ingress is created by calling the API.
For clusters of v1.23 or later, use the parameter ingressClassName. For details, see Creating an Nginx Ingress Using kubectl.
Only clusters of v1.21 or earlier
For details about how to use the preceding annotations, see Creating an Nginx Ingress Using kubectl.
Interconnecting with HTTPS Backend Services
Table 2 Annotations for interconnecting with HTTPS backend services
Type
nginx.ingress.kubernetes.io/backend-protocol
String
If this parameter is set to HTTPS, HTTPS is used to forward requests to the backend service container.
For details about application scenarios and use cases, see Configuring HTTPS Backend Services for an Nginx Ingress.
Creating a Consistent Hashing Rule for Load Balancing
Table 3 Annotation of consistent hashing for load balancing
Type
nginx.ingress.kubernetes.io/upstream-hash-by
String
Enable consistent hashing for load balancing for backend servers. The parameter value can be an Nginx parameter, a text value, or any combination. For example:
  • nginx.ingress.kubernetes.io/upstream-hash-by: "$request_uri" indicates that requests are hashed based on the request URI.
  • nginx.ingress.kubernetes.io/upstream-hash-by: "$request_uri$host" indicates that requests are hashed based on the request URI and domain name.
  • nginx.ingress.kubernetes.io/upstream-hash-by: "${request_uri}-text-value" indicates that requests are hashed based on the request URI and text value.
For details about application scenarios and use cases, see Configuring Consistent Hashing for Load Balancing of an Nginx Ingress.
Customized Timeout Interval
Table 4 Customized timeout interval annotations
Type
nginx.ingress.kubernetes.io/proxy-connect-timeout
String
Customized connection timeout interval. You do not need to set the unit when setting the timeout interval. The default unit is second.
Example:
nginx.ingress.kubernetes.io/proxy-connect-timeout: '120'
Customizing a Body Size
Table 5 Annotations of customizing a body size
Type
nginx.ingress.kubernetes.io/proxy-body-size
String
When the body size in a request exceeds the upper limit, error 413 will be returned to the client. You can use this parameter to adjust the upper limit of the body size. The basic unit of the parameter value is byte. You can use units such as KB, MB, and GB. The unit conversion is as follows:
1 KB = 1024 bytes, 1 MB = 1024 KB, 1 GB =1024 MB
Example:
nginx.ingress.kubernetes.io/proxy-body-size: 8m
Two-Way HTTPS Authentication
Nginx Ingress supports two-way HTTPS authentication between the server and client to ensure secure connections.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Run the following command to create a self-signed CA certificate:
    openssl req -x509 -sha256 -newkey rsa:4096 -keyout ca.key -out ca.crt -days 356 -nodes -subj '/CN=Ingress Cert Authority'
    Expected output:
    Generating a RSA private key
    writing new private key to 'ca.key'
  3. Create a server certificate.
    1. Run the following command to create a request file for generating a server certificate:
      openssl req -new -newkey rsa:4096 -keyout server.key -out server.csr -nodes -subj '/CN=example.com'
      Expected output:
      writing new private key to 'server.key'
    2. Run the following command to issue the server request file using the root certificate to generate the server certificate:
      openssl x509 -req -sha256 -days 365 -in server.csr -CA ca.crt -CAkey ca.key -set_serial 01 -out server.crt
      Expected output:
      Signature ok
      subject=CN = example.com
      Getting CA Private Key
  4. Create a client certificate.
    1. Run the following command to create a request file for generating a client certificate:
      openssl req -new -newkey rsa:4096 -keyout client.key -out client.csr -nodes -subj '/CN=Ingress'
      Expected output:
      writing new private key to 'client.key'
    2. Run the following command to issue the client request file using the root certificate to generate the client certificate:
      openssl x509 -req -sha256 -days 365 -in client.csr -CA ca.crt -CAkey ca.key -set_serial 02 -out client.crt
      Expected output:
      Signature ok
      subject=CN = Ingress
  5. Run the ls command to check the created certificates.
    Expected output:
    ca.crt  ca.key  client.crt  client.csr  client.key  server.crt  server.csr  server.key
  6. Run the following command to create a secret of the CA certificate:
    kubectl create secret generic ca-secret --from-file=ca.crt=ca.crt
    Expected output:
    secret/ca-secret created
  7. Run the following command to create a secret of the server certificate:
    kubectl create secret generic tls-secret --from-file=tls.crt=server.crt --from-file=tls.key=server.key
    Expected output:
    secret/tls-secret created
  8. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    • For clusters of v1.23 or later:
      kind: Ingress
        annotations:
          nginx.ingress.kubernetes.io/auth-tls-verify-client: "on"
          nginx.ingress.kubernetes.io/auth-tls-secret: "default/ca-secret"   # Replace it with your CA certificate secret.
          nginx.ingress.kubernetes.io/auth-tls-verify-depth: "1"
          nginx.ingress.kubernetes.io/auth-tls-pass-certificate-to-upstream: "true"
        namespace: default
        rules:
        - host: example.com
          http:
            paths:
            - backend:
                service:
                  name: nginx-test  # Replace it with the name of your target Service.
                  port:
                    number: 80  # Replace it with the port of your target Service.
              path: /
        tls:
        - hosts:
          - example.com
          secretName: tls-secret   # Replace it with your TLS certificate secret.
        ingressClassName: nginx
    • For clusters of v1.21 or earlier:
      apiVersion: networking.k8s.io/v1beta1
      kind: Ingress
        annotations:
          kubernetes.io/ingress.class: nginx
        namespace: default
        rules:
        - host: example.com
          http:
            paths:
            - path: '/'
              backend:
                serviceName: nginx-test  # Replace it with the name of your target Service.
                servicePort: 80  # Replace it with the port of your target Service.
        tls:
        - hosts:
          - example.com
  9. Run the following command to create an ingress:
    Expected output:
    ingress.networking.k8s.io/ingress-test created
  10. Run the following command to obtain the IP address of the ingress:
    kubectl get ingress
    Expected output:
    NAME         CLASS   HOSTS         ADDRESS      PORTS     AGE
    nginx-test   nginx   example.com   10.3.xx.xx   80, 443   27m
  11. Run the following command to update the IP address of the ingress into the hosts file and replace the following IP address with the actual IP address of the ingress:
    echo "10.3.xx.xx  example.com" | sudo tee -a /etc/hosts
    Expected output:
  12. Verify the configuration.
    • The client does not send the certificate for access.
      curl --cacert ./ca.crt  https://example.com -k
      Expected output:
      <html>
      <head><title>400 No required SSL certificate was sent</title></head>
      <body>
      <center><h1>400 Bad Request</h1></center>
      <center>No required SSL certificate was sent</center>
      <hr><center>nginx</center>
      </body>
      </html>
    • The client sends the certificate for access.
      curl --cacert ./ca.crt --cert ./client.crt --key ./client.key https://example.com
      Expected output:
      <!DOCTYPE html>
      <html>
      <head>
      <title>Welcome to nginx!</title>
      <style>
      body {
          width: 35em;
          margin: 0 auto;
          font-family: Tahoma, Verdana, Arial, sans-serif;
      </style>
      </head>
      <body>
      <h1>Welcome to nginx!</h1>
      <p>If you see this page, the nginx web server is successfully installed and
      working. Further configuration is required.</p>
      <p>For online documentation and support please refer to
      <a href="http://nginx.org/">nginx.org</a>.<br/>
      Commercial support is available at
      <a href="http://nginx.com/">nginx.com</a>.</p>
      <p><em>Thank you for using nginx.</em></p>
      </body>
      </html>
Domain Name Regularization
Nginx Ingress allows you to configure the nginx.ingress.kubernetes.io/server-alias annotation to configure regular expressions for domain names.
  2. Create a YAML file named ingress-test.yaml. The file name can be customized.
    For example, the regular expression ~^www\.\d+\.example\.com$,abc.example.com indicates that you can access the ingress using www.{One or more digits}.example.com and abc.example.com.
      kind: Ingress
        annotations:
          nginx.ingress.kubernetes.io/server-alias: '~^www\.\d+\.example\.com$,abc.example.com'
        namespace: default
        rules:
        - host: example.com
          http:
            paths:
            - backend:
                service:
                  name: nginx-93244  # Replace it with the name of your target Service.
                  port:
              path: /
      kind: Ingress
        annotations:
        namespace: default
        rules:
        - host: example.com
          http:
            paths:
            - path: '/'
              backend:
  3. Run the following command to create an ingress:
    Expected output:
  4. Check the NGINX Ingress Controller configuration.
    1. Run the following command to check the NGINX Ingress Controller pods:
      kubectl get pods -n kube-system | grep nginx-ingress-controller
      Expected output:
      cceaddon-nginx-ingress-controller-68d7bcc67-dxxxx        1/1     Running   0          18h
      cceaddon-nginx-ingress-controller-68d7bcc67-cxxxx        1/1     Running   0          18h
    2. Run the following command to check the NGINX Ingress Controller configuration:
      kubectl exec -n kube-system cceaddon-nginx-ingress-controller-68d7bcc67-dxxxx -- bash -c 'cat /etc/nginx/nginx.conf | grep -C3 "example.com"'
      Expected output:
               ## start server example.com
               server {
                        server_name example.com abc.example.com ~^www\.\d+\.example\.com$ ;
                        listen 80  ;
                        listen [::]:80  ;
               ## end server example.com
  5. Run the following command to obtain the IP address of the ingress:
    kubectl get ingress
    Expected output:
    nginx-test   nginx   example.com   10.3.xx.xx   80      14m
  6. Use different rules to test service access.
    • Run the following command to access the service through Host: example.com:
      curl -H "Host: example.com" 10.3.xx.xx/
      It is expected that the web page can be accessed properly.
    • Run the following command to access the service through Host: www.123.example.com:
      curl -H "Host: www.123.example.com" 10.3.xx.xx/
    • Run the following command to access the service through Host: www.321.example.com:
      curl -H "Host: www.321.example.com" 10.3.xx.xx/
Documentation
For details about annotation parameters supported by Nginx Ingress, see Annotations.
