Configuring an HTTPS Certificate for an Nginx Ingress
HTTPS certificates can be configured for ingresses to provide security services.
  1. Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
  2. Ingress supports two TLS secret types: kubernetes.io/tls and IngressTLS. IngressTLS is used as an example. For details, see Creating a Secret. For details about examples of the kubernetes.io/tls secret and its description, see TLS secrets.
    Create a YAML file named ingress-test-secret.yaml. The file name can be customized.
    vi ingress-test-secret.yaml
    The YAML file is configured as follows:
    apiVersion: v1
    data:
      tls.crt: LS0******tLS0tCg==
      tls.key: LS0tL******0tLS0K
    kind: Secret
      annotations:
        description: test for ingressTLS secrets
      namespace: default
    type: IngressTLS
    In the preceding information, tls.crt and tls.key are only examples. Replace them with the actual files. The values of tls.crt and tls.key are Base64-encoded.
  3. Create a secret.
    kubectl create -f ingress-test-secret.yaml
    If information similar to the following is displayed, the secret has been created:
    secret/ingress-test-secret created
    Check the created secret.
    kubectl get secrets
    NAME                         TYPE                                  DATA      AGE
    ingress-test-secret          IngressTLS                            2         13s
  4. Create a YAML file named ingress-test.yaml. The file name can be customized.
    vi ingress-test.yaml
    For clusters of v1.23 or later:
    kind: Ingress
      namespace: default
      tls:
      - hosts:
        - example.com
        secretName: ingress-test-secret  # Replace it with your TLS key certificate.
      rules:
        - host: example.com
          http:
            paths:
              - path: /
                backend:
                  service:
                    name: <your_service_name>  # Replace it with the name of your target Service.
                    port:
                      number: <your_service_port>  # Replace it with the port number of your target Service.
                property:
      ingressClassName: nginx
    For clusters of v1.21 or earlier:
    apiVersion: networking.k8s.io/v1beta1
    kind: Ingress
      annotations:
        kubernetes.io/ingress.class: nginx
      tls:
      - hosts:
        - example.com
      rules:
      - host: example.com
        http:
          paths:
          - path: '/'
            backend:
              serviceName: <your_service_name>  # Replace it with the name of your target Service.
              servicePort: <your_service_port>  # Replace it with the port number of your target Service.
  5. Create an ingress.
    If information similar to the following is displayed, the ingress has been created:
    ingress/ingress-test created
  6. Check the created ingress.
    kubectl get ingress
    NAME          CLASS   HOSTS         ADDRESS    PORTS   AGE
    ingress-test  nginx   example.com              80,443  10s
  7. Enter https://example.com in the address box of the browser to access the workload (for example, Nginx workload).
    Replace example.com with your domain name.
